Originally Posted by DoubleVision
Getting a roller cam to use with a fuel pump lobe is easy. Most of the cams that came in TPI engines have the fuel pump lobe. Or you can usually score a GM cam on Ebay on the cheap that have them as well.
Why I specified the use of a Vortec oil pan is because Vortec engines have longer bolts that are used to support the windage tray and I am unsure if the 87 and up pans have enough clearance to clear the longer bolts.
The main cap bolts that the windage tray bolts to are not long enough to affect the oil pan for any 87 and up engine... its fine, I used a vortec pan on My lt1 the main cap bolts for the windage trays are only slightly taller, plenty of room.
