-   -   572 with blower (http://www.hotrodders.com/forum/572-blower-232907.html)
prumora1 05-15-2013 04:47 PM
572 with blower
I am putting a 8-71 on a 572, do the heads and block need to be machined to accept the rings style head gasket
68NovaSS 05-15-2013 04:59 PM
Ring style head gasket? If you're referring to "O" ringing the block, which is not part of a head gasket, yes. Unless you're going to be running an obscene amount of boost, why do that?
techinspector1 05-15-2013 06:36 PM
Here's the scoop on copper gaskets used with o-rings....
Copper Gasket Tech
Counsel with your blower supplier guy about the need for o-rings.
killeratrod 05-15-2013 07:46 PM
sure would like to see your motor and blower combo. post some pictures!
prumora1 05-15-2013 08:02 PM
I was reading on a head gasket that has a .050 wire incorporated in the gasket itself, so im not sure if it would still be considered "O" ringing the block, but if so that's fine, also plan on running no underdrive and producing about 12 to 15 lbs of boost
metalstorm 05-15-2013 08:13 PM
On a 572 I don't think it will make 12# of boost underdriven.
68NovaSS 05-15-2013 08:35 PM
15 pounds of boost huh? What's your SCR? Even as low as 8.5:1, you realize your effective c.r. will be 17.8:1? You won't do it on 92 pump gas, even with meth injection you'd be pushing it.
To make 12.1 pounds of boost in a 540 motor you would need to overdrive an 8-71 30%, I'd estimate a 572 will require at least 40% overdriven to get 15 pounds. 1:1 in a 540 will make 6 pounds.
vinniekq2 05-15-2013 09:11 PM
Are you building a tall deck or standard deck engine? (curious) a couple turbos would be nice and easier to hide
metalstorm 05-16-2013 05:33 AM
If you are going to under drive the blower then no need to o-ring,The cr will be under 14/1 and a good race gasket will work.Is you block,heads prepped for MLS gasket?
prumora1 05-24-2013 09:17 PM
572 with 8:71
I would love to post pics but the engine is in process of being built, that's why im getting info now,
I spoke to a local builder but not a big supercharger kind of person, but he suggested to "O" ring the block with a high quality head gasket with an acceptance grove in the heads.
ap72 05-24-2013 09:30 PM
Pretty standard for high boost. May be a little overkill, may not.
68NovaSS 05-24-2013 11:19 PM
You have two threads, same subject and questions, they've been merged here.
1Gary 05-24-2013 11:37 PM
Jim Oddy is retired now.If you could find him maybe you could convince him to help you out.
camaroman7d 05-24-2013 11:54 PM
Is this a street car? What type of fuel do you plan to run? An 8-71 on a 572ci engine and trying to make 12 to 15lbs of boost, you will need decent fuel.
No need to O-ring the heads or block. A MLS gasket will handle double that boost level. You may want to talk to a few other engine builders that have played with forced induction in the last 15 years. Unless this is a very high boost alcohol deal there is really no need to O-ring it.
prumora1 05-26-2013 08:48 AM
methanol at 99.9% pure from alky is fuel of choice
