-   -   572R Oil Pressure (http://www.hotrodders.com/forum/572r-oil-pressure-231523.html)
Edward5 04-05-2013 08:43 AM
572R Oil Pressure
I have a 572R I purchased new and have run it in my race car trouble free for three years. The oil pressure stayed on zero the last time I cranked it. I have tried three gauges, all zero. It goes to 20 psi when first fired up, but only for 1-2 seconds and then zero. It normally runs 70 psi at 1400 RPM. Does anyone know where I can get an oil flow diagram for this motor, or any late model big block Chevy? Any ideas?:confused:
spinn 04-05-2013 08:50 AM
Was the distributor recently reinstalled? There might not be contact shaft to oil pump .
2speed_1 04-05-2013 11:05 AM
oil pressre
Do not run the engine any more till you have taken down the oil pan and verify that the oil pick up tube has not fallen/broke off. bearing damage etc. you already know it's not the gauge.Had the pick up break free on one my race engine years ago and it was expensive!!!!
painted jester 04-05-2013 02:43 PM
Race car engine? 3 years trouble free? I'd say pull it and go through it! I build + race and go through them during the week to run the next week end let alone 3 years, You got a lot of life out of a race engine unless you haven't accumulated any hours on it over 3 yrs or 3 race seasons.
Jester
Edward5 04-06-2013 09:48 AM
572 Oil Pressure
Spinn, No the distribitor has not been removed. Thanks,Edward5
spinn 04-06-2013 11:00 AM
Put a mechanical gauge on it, and turn the oil pump by hand with a priming rod.
1Gary 04-06-2013 01:33 PM
Three yrs of racing and not freshen up??. You owe alot more to it than it owes you.Time to get yer hands dirty.
ap72 04-06-2013 03:12 PM
Guys, it could be three years of just driving it on and off a trailer. I would pop the pan off though and check the pump, pickup, and bearings.
