58 chevy shift linkage change - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2011, 07:17 AM
I have a 1958 chev Bel Air changing transmission from powerglide to a TH350 need to change the linkage is thier a kit available hope you can help
Old 04-21-2011, 08:01 AM
poncho62's Avatar
Wiki Edits: 5
I changed from the powerglide to a T350 in my 1962.Canadian Pontiac, same setup
You will have the short cast iron Powerglide, so you will have to shorten the driveshaft.....As for the linkage, I just had to bend mine a bit to fit...The 2 speed column shifter still worked fine, just the letters were out a bit.
Shift linkage - 79 C-10 Chevy Torque454 Hotrodding Basics 6 07-09-2010 11:19 PM
Shift Linkage - Does this look right? Torque454 Transmission - Rearend 2 03-05-2010 07:15 PM
Turbo 400 shift linkage mred Transmission - Rearend 2 07-31-2006 11:55 PM
Shift Linkage starman141b Transmission - Rearend 3 12-22-2004 06:19 PM
shift linkage dusterbd Transmission - Rearend 5 09-15-2002 11:00 AM
