58 panel rear end, change the ring and pinion? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2011, 09:24 PM
68ragtop's Avatar
Have a 58 panel truck gears are to steep for me for highway cruising 70 miles hour turning 4000rpms can you change out the ring and pinion or do I need to go with a different rear end.? And what would work, was looking for something like the 355s I have in the goat.
Old 09-22-2011, 12:49 AM
junior stocker's Avatar
Stick an automatic with overdrive in it. Probably be a lot easier and cheaper than a gear swap in this case, and you'd have the best of both worlds.
Old 09-22-2011, 03:59 PM
There were only two gear ratios offered for that rear end. The standard 3.90 and then then the 4.10 for ones with a overdrive.
SO ...
You will need to either change the complete rear end ( which is what I did on my 55 ) or switch to a overdrive transmission. Your engine ... will be a determining factor. For most folks ... changing the complete rear end is easier ... because they want to get away from the 6 lug wheel pattern anyway. I installed a 1957 Ford 9 inch rear end under mine. Partly because I had one and ... they are strong and easy to work on. The center section bolts out ... making gear changes easy.
67 Camaro rear end needs new ring and pinion bhauto1016 Transmission - Rearend 1 05-03-2011 11:09 AM
Are my ring and pinion still ok? zildjian4life218 Transmission - Rearend 41 09-22-2010 11:25 AM
ring & pinion change notsure Transmission - Rearend 11 05-25-2008 06:03 PM
Ring and Pinion fred56 Transmission - Rearend 1 01-17-2005 04:45 PM
ring and pinion help Pontiacman Transmission - Rearend 0 11-13-2003 05:09 PM
