58 ranchero - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2012, 12:34 PM
58 ranchero
i have a 58 ranchero that has a 80 camaro front clip installed before i got the car. who ever installed the clip installedit at stock ride height. i,m a hot rod kind of guy so i would like to lower the front. the crossmember on the camaro clip is only 3 in off the ground stock so lowering the clip through springs or spindles is out of the question. i,m thinking of trying to put another clip in only make sure it rides lower. does any one have any idea which clip would work? or is there another way to do this. thanx craig
Old 01-15-2012, 06:53 PM
58 Ranchero
I think that you could just "Z" the camero sub-frame,m fabricate what ever you need to make the ranchero's frame rails work, keep the wheel base right and every thing square, should not be a problem with getting it back on the road, keep all of us posted as to your progress, hope this helps you out
lowmerc
SBF into 64 Ranchero curtis73 Engine 9 01-29-2010 08:02 AM
59 ranchero Kurt Interior 2 10-13-2005 12:22 AM
Ranchero Pic corder13 Hotrodders' Lounge 5 01-07-2005 06:07 PM
Ranchero, should i buy? 40fordtruck_son Hotrodders' Lounge 29 03-27-2004 04:40 PM
57 Ranchero 80Camino Hotrodders' Lounge 5 01-10-2003 09:51 AM
