58 Sedan Delivery - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 04-08-2006, 10:49 AM
djboen's Avatar
58 Sedan Delivery
57 yrs old, retired 32 yrs with Railroad industry, wintering in Yuma AZ, summers are spent in Minot, ND Recently purchased a 58 Chevy Sedan Delivery, and as usual--(it seems like all projects I acquire) the fuel gauge does not work-haha.
Old 04-08-2006, 11:02 AM
djboen's Avatar
dj's 58 sedan delivery
I recently purchased a 58 Chevy Sedan Delivery with a LT1 TPI 350 engine. While driving it home, I noticed that the fuel gauge did not work. After filling it up, still no difference. Today,while wiggling under the dash, I noticed no wires are connected to the two terminals on the back of the gauge--duh. I found two female connector, one blue and one red-- I hooked each one, turned on the key and when turning on the key, the needle would just flicker, so I reversed the wires and now it pegs out to the full reading..Any help would be appreciated.
Old 04-08-2006, 11:07 AM
advanced design's Avatar
Remember, this is to be fun!
Last journal entry: Lead Joint replacement
Welcome DJBoen,
By any chance was the fuel tank full of fuel? Are you positive one of the two leads you found run to the connector to the tank fuel sender? Check for continuity to be sure. If the tank wasn't full possible the fuel sender in the tank is bad.
Oh, I think a '58 Chevy sedan delivery would be very cool. Enjoy retirement.
Old 04-08-2006, 11:23 AM
djboen's Avatar
No, I know that the tank is not full--i have driven roughly 100 miles. I will check the sender--thanks for your help. Yes, the 58 is really a cool ride, I have always wanted a Sedan Delivery, found this one over in Hesparia, CA and couldn't live without it--ha ha.
Old 04-08-2006, 12:55 PM
poncho62's Avatar
Wiki Edits: 5
Remember...On a Chevy the sender housing has to be grounded, otherwise it will go past full and stay there. Could be your problem.
If that doesnt fix it, post a question in the electrical forum. This forum is for introductions only.
Ontario Rodders
55 Chevy Sedan Delivery or Nomad sbader7248 Hotrodders' Lounge 10 05-30-2005 01:57 AM
studebaker sedan delivery oddball170 General Rodding Tech 3 03-28-2003 08:40 AM
Sedan Delivery Dan Augustine Hotrodders' Lounge 1 11-02-2002 04:45 AM
55 Chevy Sedan Delivery or Nomad sbader7248 Body - Exterior 2 07-01-2002 09:16 PM
55 Chevy Sedan Delivery or Nomad sbader7248 Hotrodders' Lounge 0 06-28-2002 05:09 PM
