58cc small block chevy heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2012, 01:07 PM
what kind off power can i get by puting these heads on a 1989 350 block with a 4 barl holley carb thanks
Old 06-05-2012, 01:16 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
There is no where near enough information given to know. My guess is 43.2hp. We need to know more about the engine including cam specs, current compression, current cylinder heads, what cylinder heads these 58cc heads are you speak of, intake, exhaust, timing, and carb will all be helpful.
Old 06-05-2012, 01:24 PM
Is the block decked? Or are the pistons 'down in the hole'; if so, by how much
my guess? 53.625hp and 23lbft of tq
Old 06-05-2012, 05:10 PM
all l can tell you right now is the engine is from a 1989 chevy van, 350..throttle body. And l'd like to put these heads on it. Thinkin about putting cam's in it. Dont know for sure if going to do it. The head casting numbers for the head l want to put on is 14022601.Going to put some type of aftermarket intake on it with either 600 holley or 750 holley with hei (the two wire style) Shorty headers thanks
Old 06-05-2012, 06:02 PM
GMCBEAST's Avatar
You can expect better low end power for sure, but without working those heads you won't be making much power past 4,500 or so rpms. Good for a daily driver with weight unless you dig deeper on the combo and heads.
Old 06-05-2012, 08:02 PM
dose any 1 know how much lift i can get out of these head ..stock head , could i put a rv cam in it or little biger thanks
Old 06-05-2012, 10:25 PM
spinn's Avatar
I strongly suggest vortec heads with rv cam choice. Thet are getting pretty cheap and they work.
58cc factory heads are not solidest of performers.
Old 06-06-2012, 02:12 PM
I did a build with 58 cc Trickflow 87-95 Centerbolt heads with 175 cc runners and was very happy with the results of a TBI 350. It had 9.7:1 compression a XE256 comp Camp with 1.6:1 rockers. Tuned chip from Brian at TBI Chips. Ran 454 TBI injectors, and a matched 50mm TBI intake. Very torquey and good top end for a TBI engine. My point here is use good parts. Trickflow, AFR heads really make the difference.
Old 06-06-2012, 03:35 PM
cool rockin daddy's Avatar
5% more hp than what you have now for every 1 point increase in compression. That engine probably struggles to make 180 HP. You're looking at 9-18 more HP max with just a head change.
Old 06-06-2012, 07:43 PM
the engine is 1990 ls9 350 ... could some 1 tell me a ruff guess of compression using these head on this stock block thanks
Old 06-06-2012, 08:16 PM
spinn's Avatar
for real?
Say you have 58 cc heads, .040 gasket, .030 overbore, the pistons have about 5-10cc of space between the gasket surface, that is the neighboorhood of 11:1.
Swept 350 volume 716cc or so, and total combstion volume being around 70 something.
Old 06-10-2012, 10:31 PM
spinn's Avatar
Your right I guess I failed the math. Divide 716 by 70 something. Ha, like the neighboorhood of 10:1.
The Following User Says Thank You to spinn For This Useful Post:
fordss (10-08-2012)
small block chevy heads joey1982 Hotrodding Basics 1 03-06-2012 07:26 PM
Stock, BUDGET 400sbc. 58cc heads too small? MrChevyDC3 Engine 11 02-15-2011 06:58 AM
Can You I D a Block & Heads Small Block Chevy please? Rob Keller Engine 19 01-30-2011 08:39 AM
Small Block Chevy Heads - 487X stfinney Engine 14 06-14-2010 04:09 PM
Chevy Small Block Heads druss32 Engine 17 05-10-2006 08:35 PM
