'59('57?) Dodge Truck 354 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2012, 11:03 AM
ewoky409
Hi. I have a 354 Power Giant hemi from a '57 Dodge truck.I can't locate the engine number in any database I've checked though.I was told when I bought it that it is a '59 engine,but from the head casting number I find at least the heads are from a '57.The engine number is:M354-1601.The M series engines were made in 1959,but all of them have just the M and one digit.Mine has the M and three digits(M354 instead of M6,M7,M8 etc.).Any help from someone who knows or has this info would help a lot.I plan to modify this engine,but I need the original specs to help me chase down parts etc. Thanks
Old 02-10-2012, 01:21 PM
Wiki Edits: 49
When it comes to early Chrysler hemis, especially the truck stuff, a lot of their ID codes aren't in any database. Your engine could be a Canadian version or a replacement block, its impossible to know for sure, so don't be all that concerned about that part of it.
Now, the thing to remember is that the general specs for any 354 will work for yours. That said, if your engine came from a heavy truck the heads will have a taller water crossover that will not seal against a stock automotive or aftermarket intake manifold. The solution is to pick up another set of heads or you can have the top of the water passage welded to bring down the top so it will seal. You'll wan to replace the normal internals, pistons, valves, cam, lifters, push rods etc. If your engine has adjustable rockers I'd keep them. They're hard to find and you can use a solid lifter cam with those. If you don't want to use a solid cam then you can sell them and probably make enough to buy a reconditioned set of non adjustable rockers, new cam, lifters, and adjustable push rods. You may also want to use an aftermarket front cover and convert to a BBC water pump. Hotheads has those and just about any other parts you'll need.
Good luck with your build.
Centerline
HotRodsAndHemis.com
"Running a small block Chevy is like having a girlfriend who wears a push-up bra. The numbers look great, but once you get under the hood, there's not as much there as you thought." - Anonymous
48 dodge truck rat rod skrapdaddy Introduce Yourself 4 10-16-2009 07:00 PM
anyone have pix of a rat rod 38-46 dodge truck? 38gangster Hotrodding Basics 2 07-23-2007 09:49 PM
Dodge truck mfd561 Electrical 2 12-19-2006 06:48 PM
AT w/od for Dodge truck JlCoffell Transmission - Rearend 2 09-04-2003 07:47 PM
73 dodge truck Rodder318 Body - Exterior 2 04-05-2003 09:48 AM
