'59 Apache to '56 Chev front tin swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2009, 01:35 PM
Rusty59's Avatar
Last journal entry: Drop axle install
I'm working over my beater '59 Apache and am considering changing out the complete front tins. A friend of mine has the set from a 1 ton '57, inc the fenders, hood, lower valance and core support. The '57 tins are in better shape, and I like the look of the earlier stuff better. To make the Frankentruck deal complete, I want to use a '55 or '56 grill, which in theory, should also fit the '57. Can anyone point me to an article or thread about doing this? How compatable are the parts?
Old 06-07-2009, 09:49 AM
bobjob's Avatar
try 1947-present chevrolet & gmc truck message board ,,,or '67-72 chevy trucks .com..
Old 06-07-2009, 11:12 AM
DOUBLEDICK's Avatar
Rusty59 the frame horns on the 58-59 are longer than the 55-57.You will have to trim them back to make the early tins work.I believe the core support is farther out on the 58-59.Measure the frame on the donor truck and drill the holes for the core support.Pre-assemble the front clip then mount it on the 59.I think the hood hinges are different on the 57 as well but the cabs are the same so the fenders should bolt up ok.Good luck with your project and hit the "55 to 59 chevy truck owners" thread and post your progress.I would like to see how it comes out
Old 06-07-2009, 10:19 PM
Rusty59's Avatar
Darn good idea! My running mate Gunney has the tins off his '57 Cameo, so I'll measure his and compare. I'll make sure to get everything forward of the cab since the inner fenders are bound to be different as well. So far, it doesn't sound like too big a deal.
56 Chev Wagon/Sedan quarter compatibility? KYLEdallas Body - Exterior 2 12-28-2006 09:11 PM
Front Rotor Swap 83_Chevy Suspension - Brakes - Steering 5 03-11-2006 01:21 PM
56 chev Questions outlaw17 Body - Exterior 3 03-05-2006 09:18 AM
56 chev power steering cols56 Suspension - Brakes - Steering 1 07-25-2005 05:06 AM
a front clip for a 56 chev car car_guy_39@hotmail.c Suspension - Brakes - Steering 1 07-20-2005 11:04 PM
