59 Apache Axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2011, 08:17 PM
59 Apache Axle
Does anyone know if i can put a 98 transam axle on a 59 apache truck? A friend of mine has the axle sitting in his garage from a TA that was totaled (front end damage).
Old 11-03-2011, 09:24 PM
I guess I should have mentioned that i have the original rear axle for the 59 apache truck currently installed. I want to put an LS1 engine out of a 98 trans am ram air into the truck. Does anybody know if the stock rear would have any issues handling this engine?
Old 11-04-2011, 04:44 AM
cal1320's Avatar
I have a 56 Chevy truck and used an '87 F body rear axle. 1993 and up axles are about 4'' wider than the 70-81 and 82-92 camaro axles. Strength wise, third and fourth gen f body axles they aren't that great as they have 7.5/7.625'' ring gears. As a cruiser it's OK. Beat on it and it will break. The 94 and up caprice/Impala has a 8.5'' axle and the width is the same as the truck. However it has a 5 on 5 bolt pattern. For heavy hp application, use a 9'' or 8.8'' ford. The Ford Exploder has a 8.8 and is 60'' wide (2'' less than stock). Later ones had disc brakes and up to 4.10 axle ratios.
Old 11-04-2011, 07:19 AM
Well that sucks....I have a the TA axle readily available.....thanks for the information.
Chevy Apache Rear Axle / Diff stumper... Texan593 Transmission - Rearend 2 09-20-2011 01:24 PM
59 apache wiggim Hotrodding Basics 1 10-15-2010 09:55 AM
7.5 Axle id and ? about narrowing using ranger axle shafts johnhalabama Transmission - Rearend 4 07-23-2009 05:12 PM
4x4 axle conversion ttb to solid front axle. Jared Transmission - Rearend 6 11-07-2005 08:50 PM
58 apache thadskingdom Engine 13 01-26-2004 09:14 PM
