Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 59 chev alignment
Old 07-14-2006, 12:28 PM
matt167 matt167 is online now
Wiki Edits: 31
I'm no expert on alignment but I did have to learn about all the angles, and I'v done a couple allignments at the autoshop class I took with a John Bean system. toe in/ out does not need to be 0, it should be but as long as the 2 tires read the same, they are good, otherwise you will get a pull. caster is a non tire wearing angle that helps the wheels return to center, and camber is ajusted for road crown, so the road don't cause a pull like it will with 0 camber, usally put a couple * negative on the right to compensate for road crown.
