Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 59 chev alignment
Old 07-14-2006, 01:36 PM
matt167 matt167 is offline
Wiki Edits: 31
if you arn't happy with the allignment results then get a castor/ camber gauge that measurs in degree's ( not the bubble leval 1 that sells for $40 ) and a tape measure and a friend, because you can ajust toe in/ out by measuring across the front of the tires and rear of the tires to get a toe in/ out measurement, ajust the tie rods until the front and rear measurements are equal, primative way but it does work.
