59 Chev pu 5 hole drums? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2005, 11:59 AM
stayin busy
Hi, got a question for the task force experts. Does anyone know of a 5 lug brake hub/drum unit that will fit on the front of a 59 chev pu? I've searched the forum and can't find anything pertaining to this.
Anyway, I used to have a 56 with this set up on it so I know it is possible. (I bought it that way.)
I wanted to find some slot mags with the 6 hole pattern,but i can't find them in the sizes I want without paying a fortune for some obsolete ones. As this is the case, I want to go with a 5 spoke wheel with a 5 bolt pattern. I'm on a budget right now, so I would like to use drums until I can afford the IFS and/or disc brake set up.
Can anyone help? Any suggestions?
Thanks, K.B.
Old 05-28-2005, 12:19 PM
gator412's Avatar
1955 2nd series Chevy Pick Up
Last journal entry: Body work and U bolts
I went with CPP to put disk on my 1955 2nd series Chevy truck
[/url]www.classicperform.com/product-pages/trucks/five-lug-disc-brake-wheel-kit.htm[/url]
Hope this helps
Old 05-28-2005, 12:57 PM
Originally Posted by KennyB
I want to go with a 5 spoke wheel with a 5 bolt pattern. I'm on a budget right now, so I would like to use drums Can anyone help? Any suggestions?
Thanks, K.B.
Find a set of stock 53 and 54 Chevrolet passenger car front drums and hubs....( they are 5 lug )
They will interchange with your 6 lug stuff.........
I would turn the 5 lug drums and repack the wheel bearings.
When I did this MANY years ago on my 55 Cameo........I bought new bearings and races......because I had no intentions of going to disc brakes.
Old 05-28-2005, 03:15 PM
stayin busy
Thanks Duece. Good info. I'll try to find one of the early fifties cars. Thanks also Gator, I'll look up that site when I get to that point.
39 chev PU hanging pedel stea Suspension - Brakes - Steering 6 05-31-2005 11:12 AM
56 chev pu suspension upgrade George Gold Introduce Yourself 3 08-10-2004 01:47 AM
1952 Chev PU Fatman Ultralow done need to get the back down to match? SkippyCraig Suspension - Brakes - Steering 4 02-29-2004 01:06 AM
Updated axle housing for '50 Chev PU Maggie Transmission - Rearend 4 09-03-2003 10:40 AM
IFS on '51 Chev PU Berns Suspension - Brakes - Steering 0 10-01-2001 01:20 PM
