59 Chevy Apache - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2012, 07:07 PM
59 Chevy Apache
I want to mate a older model version T-5 OUT OF A v6 S-10 to my 235 stovebolt anyone else done this conversion that would share info would be most appreciated thanks.
Old 06-11-2012, 08:10 PM
KA67_72's Avatar
I have a 350 with an old style cast iron bellhousing in my '59. The bolt pattern is the same as the newer belhousings. I have a wc t-5 out of a Camaro. One hole and the front bearing retainer will line up with the bellhousing. I welded and redrilled the other upper bolt. On the bottom I bolted a 3/8 plate to the bellhousing. Then I bolted to 3/8 tabs to the trans and welded the 3/8 pieces together. It's not presentable but I'll get a pic tomorrow.
Kevin
Old 06-11-2012, 09:56 PM
RWENUTS's Avatar
Some links for ya!!
http://67-72chevytrucks.com/vboard/s...d.php?t=438224
http://www.jalopyjournal.com/forum/s...5+transmission
And one more.
http://www.jalopyjournal.com/forum/s...3&highlight=t5
1958 chevy apache dbrianb Body - Exterior 2 07-21-2011 03:58 PM
58-59 Chevy Apache Owners Craig legacy Hotrodders' Lounge 1 04-30-2009 09:19 PM
'59 chevy apache k1ll3ry0d4 Body - Exterior 2 09-24-2007 05:04 PM
58 chevy apache shelbee Body - Exterior 3 01-05-2005 05:03 PM
58 Chevy Apache thadskingdom Engine 2 02-26-2004 10:11 PM
