59 chevy gas tank re-location - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2008, 05:50 PM
Just looking for any ideas on where to relocate the gas tank. Where should I install the new tank and what kind of tank or where can I get a new tank to use?
Old 02-12-2008, 05:52 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
The stock location is the easiest and safest. Why do you feel the need to move it?
Old 02-12-2008, 05:56 PM
I already took the tank out and patched up the hole. I was afraid of smelling gas fumes.
Old 02-12-2008, 06:00 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Is this a car or a pick-up? Give us some info.
Old 02-12-2008, 06:01 PM
It is a pickup it has the fleetside longbed.
Old 02-12-2008, 06:02 PM
Lost in the 60's
Wiki Edits: 4
And your tank location is behind the seat? If so as long as the tank was repaired properly and the connecting hoses, lines, etc. are in good condition...I would leave the tank in its original location.
Old 02-12-2008, 06:05 PM
yeah the stock location is behind the seat. I had my great idea to take it out and I patched the hole where the fill neck was. So I didnt know if there was a common relocation place to put a new tank or should I just put it back to where it was?
Old 02-12-2008, 06:12 PM
Alot of people use a rear mount blazer or suburban tank.
Shane
Old 02-12-2008, 06:14 PM
AntnyL's Avatar
The most common location for a relocated tank is between the frame rails, behind the rear axle. Some folks will argue that leaving the tank behind the seat is a safety hazzard; in case of a t-bone or rollover, gas can splash all over the driver/passengers and catch fire, so relocating is a safe thing to do. Hard to argue with that logic.
Call CPP, Brothers, Classic Industries, etc. They all carry relo tank kits.
Antny
Old 02-13-2008, 12:35 AM
Senior Curmudgeon
Wiki Edits: 326
"The most common location for a relocated tank is between the frame rails, behind the rear axle. Some folks will argue that leaving the tank behind the seat is a safety hazzard; in case of a t-bone or rollover, gas can splash all over the driver/passengers and catch fire, so relocating is a safe thing to do. Hard to argue with that logic."
I agree, I was picturing a passenger car when I posted
Old 02-13-2008, 07:15 AM
thanks for all your help. I will look in to some options on some tanks. Thank you cery much
welding on gas tank oldred Hotrodders' Lounge 15 01-21-2012 10:49 AM
47-48 chevy truck gas tank 49_chevy_truck General Rodding Tech 8 01-25-2006 03:56 AM
Gas Tank Plumbing Follow-Up Doc68 Engine 0 01-11-2004 07:28 PM
1950 Chevy Gas tank etc baddogspike15 Interior 8 02-23-2003 04:39 PM
'49 Chevy PU Gas Tank Relocation hiimed Engine 11 02-04-2003 02:50 PM
