-   -   59 chevy stepside sheet metal replacement? (http://www.hotrodders.com/forum/59-chevy-stepside-sheet-metal-replacement-103372.html)
billg_69gmc 11-27-2006 05:25 PM
Hey all,
I'm in the process of replacing bad sheet metal on my 59 chevy stepside.
The toeboards need replacing, along with the lower door hinge pillar.
Is it a best practice to just work on on piece at a time, or since they join to work on them at the same time? My plan is to do one side at a time, not both at once to maintain as much ridgitity as possible.
thanks
billg
colormecrazy 11-27-2006 05:32 PM
That's a matter of preference. If it is easier to put them in together, go for it. But, as you've stated, I would not advise doing both sides at ones.
DOUBLEDICK 11-28-2006 04:27 PM
billG in the hotrodders lounge is the thread"55 to 59 chevy truck owners"there are some guys with project journals that may be of help to you.check it out. :thumbup:
billg_69gmc 11-28-2006 08:13 PM
sheet metal work
thanks DD, I will search that out. I definitely want to limit my mistakes and this is the place to squash them! Thanks!!
billg
