Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 06-12-2007, 10:51 AM
TMCRacing TMCRacing is offline
59 El Camino Disc Brakes
Looking for a cheap way to get disk brakes. I have s10 spindles, can I just weld a ball joint socket on the bottom A frame and use this spindle? What other parts interchange to make this work?
What parts do I use if I just buy the conversion brakets for the s10 calipers?
Old 06-12-2007, 01:29 PM
Bryan59EC's Avatar
Bryan59EC Bryan59EC is offline
Car? Truck? Who Cares
re: 59 El Camino Disc Brakes
There is actually a bracket that will allow you to use the stock spindle.
Not too sure what caliper or rotor will be needed though.
Stock height spindles are being reproduced for these cars as well
Or you can go with a kit---as I did
2" drop spindles----I think it uses malibu rotors and camaro calipers.
Not too sure---can't remember
If you look thru a Classic Performance Products catalog, it will eventually tell you what calipers and rotors to use with any kit, just have to really look.
Bryan
Old 06-12-2007, 05:22 PM
59 wagon man 59 wagon man is offline
i don't think s10 calipers were designed for the job of stopping a 59 el camino . i have converted my wagon to disc brakes and all the kits seem to use rotors and calipers from a mid 70's chevelle.use stock spindles and with the right bearings and brackets its a bolton. as a matter of fact i have a kit for sale pm me if your interested
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "59 El Camino Disc Brakes"
79 El Camino Rear Disc brake conversion Nailhead Suspension - Brakes - Steering 3 04-06-2007 03:32 PM
71 el camino disc brake conversion stu_yoakam Suspension - Brakes - Steering 5 03-19-2007 03:34 PM
Finding 72 El Camino Disc Brakes sb72elcamino350 Suspension - Brakes - Steering 2 03-19-2004 05:35 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 02:34 PM
59 el camino who wants to trade? DragLinkscc Hotrodders' Lounge 0 11-13-2002 11:24 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
