That did not work. I took out the alternator and took it to discount and had them check it. It turns out to be bad, it was only pushing out 10 volts. I bought a new one and connected the voltage regulator and alternator per wiring schematic. I was not able to read any voltage coming out of the voltage regultator nor the alternator itself. I also put my am meter to the battery post and the other end to the positive cable and I am still getting a current drain. I tried to connect the voltage regulator the opposite way thinking that might be it but that did not work as well. Any other suggestions? The connections that I have on the alternator are Batt, STA, ground, and one other I think it is FLP or so. On the voltage regulator it has I, A, S, F.
Thanks, Eddie |
Does it appear as a MOTORCRFAT alternator? Do you see any ID Nos. stamped on the front case? Maybe it is GM or not a 1G as most conversions of this period use? Any chances of a photo? ![]() There are two methods to excite the ALT on a FORD application. Early will have the I circuit running through the ammeter/lamp or it will have a direct connection to the fuse box (ON-OFF with IGN SW). You have to determine which was or will be used and correct the circuitry to reflect the application. -HOW TO FIX YOUR POWER DRAIN- |
It looks identical to the 1G to the tee. I will rewire the voltage regulator as I see it on the schematic. I know for sure now the reason is at the voltage regulator, I is not hooked up or it is but wrong. Thankyou. The other thing is that is entire car does not have a fuse box. It seems that the only 2 fuses are coming from the light switch itself. Weird! I will keep checking to see what I find out under the dash. Do you happen to know what size fuse would be sufficient for the alternator to battery. Thanks again for the schematic.
Here is a link I have in my favorites.I have a 56 Ford.I have not tried it yet but plan to.
http://www.ranchwagon.com/tech/alt/alt.htm |
-1957 To 1965 Wiring Diagrams- Check the appropriate diagram to see how the I (IGN) circuit is wired. If it goes through an ameter or warning lamp, it needs to be wired in that fashion to excite the ALT (and even for the engine to start). If you wire it off a key ON-OFF source, you will lose the meter/lamp. The B post fuse is a suggestion, not necessarily needed. Last edited by KULTULZ; 11-21-2007 at 11:59 PM. |
I just received the new harness and installed it. I am now trying to figure out the wiring for the voltage regulator and alternator. I connected everything per schematics that was posted. The one thing that I found strange is that the gen light stays lit without the key in. I must have something connected backwards, it will not crank either. So what I have for connections are from the alternator STA, FLD, and BATT. As for the voltage regulator I have I,A,S, and F, in that order.
The Black/yellow on the schematic should that go to ignition on the key switch? I also have some pictures I took of what I am working with but have no idea how to upload them here. Thanks, Last edited by platinummobile; 12-16-2007 at 08:05 AM. |
I found what I did wrong and it is working perfect now. I have a 14.4 charge. There is still a small drain and I believe it is coming from the horn relay that is mounted on the inner driver fender.
I should have been more concise. FORD had two methods for wiring the IGN circuit and I am not sure where the production break was (I think 1972). The Black and/or YELLOW wire is BAT feed. IGN (Green Wire) is supplied in two different ways, early production from the IGN SW through a shunt ammeter (light) and to the REG. This allows starting. Later production had the IGN supply circuit coming from the fuse box.
Run the IGN source as shown on the diagram (Wiring Diagrams) through the light to the IGN SW and see if the drain goes away. QUESTION: How did the harness supplier say how to wire it? Last edited by KULTULZ; 12-17-2007 at 07:23 AM. Reason: Ask A Question |
| '59 Ford F100 Pickup with Buick engine | birdman1 | Introduce Yourself | 5 | 11-14-2010 04:23 PM |
| Ford Voltage regulator hookup | wishnevsky | Electrical | 4 | 11-01-2007 02:23 PM |
| 59 Ford pickup w/ 84 Buick LaSabre 307 | birdman1 | Engine | 6 | 09-30-2007 11:27 AM |
| Fairlane 500 | Wisconsin Bill | Introduce Yourself | 1 | 05-23-2007 12:08 AM |
| Whatever happend to these guys? | hot_rod_kid | Hotrodders' Lounge | 20 | 12-17-2002 09:20 AM |
