Hotrodders Bulletin Board
#1
59 Pontiac 9.3 Rearend Will It hold up
I'm New to this site and in the building phase of a drag only Monza. I have a Pontiac 9.3 rearend that has been completely rebuilt with street 4.1 Richmond gears, a spool and MW 35 spline axles. It is the right width and has perfect 4 link brackets. The car will weigh about 2500 lbs, 4500 stall, powerglide, 11.5" X 30 Goodyears and a 406 World Products sbc 550 hp 495 to 507 tq from 4500 to almost 6000. My concern is the street gears. Opinions Please
#2
re: 59 Pontiac 9.3 Rearend Will It hold up
I don't think the Poncho rear will break a sweat behind a 406/glide. I had a 8-3/4" Mopar in a bracket dragster with a 454/glide and it worked fine for years.
#3
59 Pontiac Rearend
Thank you
There is one positive vote for the old school rearend. B |
#4
With the good axles and spool and having the good three rib pumpkin, I would be more worried about the 4.10 ratio being a little light..
#5
In the old days.........
Being the early 60's ........the Pontiac was the rear end of choice for most drag racers.....that were not required to run the stock rear end type. I know a fellow with a 409 409 HP 62 Bel-Air equipped with a 4 speed and slicks .....he had a Pontiac under it and left the line at 4 and 5 thousand RPMS.....without a problem...for years.... You should not have any problems in a light car with no more engine than that.. |
#6
4.1 ratio being a little lite?
I'm not sure what you mean about lite. I am concerned that the street gears will be the week point. If you think I will need 3.90s I don't know where I can get them. I will have room for a 32" tire though. I really don't know how fast this car will go. I guess about 135 +- at about ten flat. Peak engine hp is at 6300 so I can push it to 6500 with out loosing et. Of course all of this is armchair.
B |
#7
You might want to look into a higher ratio like 4.33, 4.56, 4.88. |
#8
Back then.......everything WAS street gears.....no special hardness / softness drag gears ...... |
#9
Hi, I think your question is not so much the pontiac rear as the richmond street gear, right. I have the street gears in a 3450 camaro, powerglide, ford 9 " transbrake, slicks, runs high 10's. My opinion is in your setup the richmond street gears will hold up ok. If I am on the wrong track, disregard all after Hi.
#10
Pontiac rearend
Thank you all for the good information. I think the gest is the gears will most likely hold up. Since it is what I have its a good start. I do have a second third member with 4.88 gears in it if 4.1 are to tall. Watch now 4.56s will be the key.
Back to top |
Similar Threads for: "59 Pontiac 9.3 Rearend Will It hold up"
| 1957 Pontiac Rearend | Griff | Transmission - Rearend | 3 | 01-29-2006 06:54 PM |
| pontiac rearend disassembly | xtremcablespeed | Transmission - Rearend | 5 | 12-10-2003 07:48 PM |
| Advice on Pontiac rearend/ trans swap | Vaughn68 | Transmission - Rearend | 3 | 11-25-2003 07:38 AM |
| 1977 Buick rearend will it hold up? | bdv | Transmission - Rearend | 5 | 01-30-2003 03:27 PM |
| Will a 5-speed pontiac tranny hold up to a 350?? | chevyelc81 | Engine | 4 | 05-24-2002 07:20 PM |
