Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 59 Rambler Unibody floorpan questions
Old 09-09-2012, 09:03 AM
boatbob2 boatbob2 is offline
boatbob2
Rusty Floor........
Hi,when i did my 48 ford coupe,i put the car on jackstands,and leveled it,(8 jackstands)then welded re-bar in a X pattern,front to rear,and side to side,my rockers were also rusted out,i cut the entire floor out,leaving the trans tunnel,which was good metal,then replaced rockers first,then I made up a floor section,front to rear in 1 piece, welded ON TOP of trans tunnel(overlap) about 1 inch,then same on rockers.then at the overlap,i used seam sealer,came out great...
