Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 59 Rambler Unibody floorpan questions
Old 09-09-2012, 10:54 AM
swvalcon's Avatar
swvalcon swvalcon is offline
Last journal entry: rust on lt body shell
Scott. From the looks of your pictures it looks like a mn car. If your rocker panels are good I wouldn't be to worried about cutting out the floor. I would still cut it out in sections but most of the stringth in a unibody is in the rocker panels. The hard part is trying to do a nice job on the underside when you can't turn the car over and all the work has to be done laying on your back on the floor. Just be sure what ever you do to seal it up good and try to get some epoxy on it before you undercoat. Lots of times I will epoxy both sides of new floor before I weld it in that way all you have to worry about is where you weld.
