59 truck ignition switch trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2010, 04:23 PM
garretthes's Avatar
Last journal entry: Rear Axle swap #2 (74 Camaro) part 6
First of all you should know this switch only turns on the ignition. The starter is push button. The problem is it has become intermittent. The key has to be at just the right angle to get power. Lately it has shut off with me while driving so I have to fix it.
Is it possible to repair these old switches or should I replace it? Not interested in a generic switch because this one has a mount for a dash bulb which I want to retain.
Name:	ignition switch.jpg
ID:	43880   Click image for larger version
Name:	ignition switch2.jpg
Old 02-13-2010, 06:47 PM
DOUBLEDICK's Avatar
Just replace it.The contacts inside are worn out.You can get them cheap from Classic parts or Brothers Trucks.Come join the rest of us truck guys in the hotrodders lounge.We are in the "55 to 59 chevy truck owner" thread.
Old 03-23-2010, 11:46 PM
garretthes's Avatar
update
I did manage to get the switch apart and clean it. The contacts were worn as Doubledick said. I just installed a new switch from Classic Parts
Ignition switch config coupe66 Electrical 9 01-07-2008 06:47 PM
Ignition switch riped out and stolen 68 Chevy C/10 breemijoe Electrical 1 11-10-2007 08:45 AM
Ignition switch wiring ??? primerat Electrical 2 11-10-2005 05:09 PM
ignition switch wiring daddyj Electrical 1 02-01-2003 02:19 PM
ignition switch on crown vic shagginwagonvic Engine 4 06-16-2002 08:48 PM
