5C or 670 Heads?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2011, 10:36 PM
5C or 670 Heads??
Hello everybody! Been lurking around here for a couple of weeks and finally have a good question. Im just starting my pontiac build and the engine in it is a 400 75" block and 5C heads. I am trying to build a raunchy weekend driver with a CR of about 9.5. to run on pump gas. Would milling the 5C's and a .042 gasket give me the cr and performance im looking for. Or i could buy some 670 heads for $600.00. and get dished pistons to lower the CR. The 670's also have 1.77 valvles instead of the 5c's 1.66. Which option would give me the better performance?
Any feedback is appreciated! Thanks in advance!
Cliff
Old 09-05-2011, 03:45 PM
The head charts and CR calculators will be a good place to start. Don't rely on the charts for exact chamber cc measurements to get exact volume you will have to perform a chamber measurement. You can fill the chamber with water or clay to get the ccs. Be sure you do this after a valve job since a valve job will add chamber volume.
If possible try to use a head with screw-in rocker studs. Use the CR calculator to determine compression ratio. You can also factor in head milling or having the block decked. Stock deck height has always been 0.023" throughout the production of the Pontiac engine. You can have the deck height milled to 0.0". This allows the head gasket to control quench. Just something else to consider.
This should give you a good start on head selection. The last link shows head flow numbers.
http://www.angelfire.com/fl4/pontiacdude428/HeadID.html
http://www.projectpontiac.com/ppsite...tio-calculator
http://www.spottsperformance.com/head%20id
http://users.erols.com/srweiss/tablehdc.htm#Pontiac
BT
Old 09-05-2011, 04:00 PM
LATECH's Avatar
X2 what BT said there.
I used 7H1 heads with port work and 1.77 exhausts installed, and milled to 84 CC on my 389/400
static is at 9.3 to 1, oh yeah, my block is zero decked as BT also mentioned.
Oppinions EQ lightening heads and EQ vortec heads eatonde Engine 16 02-18-2013 11:00 PM
dart heads vs vortec heads repeat Engine 48 03-10-2012 08:05 PM
462624 SBC heads vs Patriot heads?? v8hed Engine 2 05-27-2008 09:25 PM
SBC cylinder head bolts .. cast iron heads Vs Alum. heads terror385 Engine 3 08-04-2006 08:34 PM
Vortec heads or 1971 487x LT1 heads? speedfrk3 Engine 2 10-07-2002 04:12 PM
