5x120mm wheels on 5x4,75" hub? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-07-2013, 01:46 PM
el pollo's Avatar
It's shady under this tree...
Originally Posted by RWENUTS View Post
Try this real world experience!
1/4 mile bracket car with 2" studs, 9" rearend and some 5x115 charger wheels mounted up. Right rear wheel comes off at a buck ten, takes out the timing lights. After they inspected the studs and the wheel guess who got the bill!
My opinion is things are machined to match up. Close don't count. You take your chances. You've been lucky. Some haven't.
Rant over.
Now back to your regular programming!
That's how I see it. Too many instances where I've seen "close enough" scenarios turn out bad. Spacers reducing the amount of thread engagement, wrong offset causing brake interference, or bolt patterns not matching up. Heck, you know how many Hondas I see come in with acorn lug nuts on their ball seat rims?
I'm not trying to be a jerk either. But it burns me to see so many people offering up bad information, and being pissed when someone comes up and says otherwise.
  #17 (permalink)
Old 07-07-2013, 03:21 PM
Project89's Avatar
Rant over.
hmmm let me quess had sticky tires on it , u do relize track rules for anything going over a certian speed and or with stick tires require aftermarket studs and lugnuts right
go measure a set of factory wheels bet u they are out of spec by more then the difference in size to begin with
9" ford 5x5.5 drums to 5x4.5 discs? 31fordcoupe Suspension - Brakes - Steering 5 07-24-2012 07:46 PM
Ford 8.8 Explorer Rotors with 5x4.75" zildjian4life218 Transmission - Rearend 3 05-14-2011 07:33 AM
Hub Hitting Z06 Wheels DocSpeed Suspension - Brakes - Steering 0 02-06-2009 09:43 PM
5X4-3/4 Chevy Hub to 39 Chevy Spindle les88404 Suspension - Brakes - Steering 5 10-31-2007 09:27 AM
79-93 Mustang 8.8" Rear Differential Width From Hub-To-Hub nightrain_rod Transmission - Rearend 1 12-04-2003 07:59 AM
