6.0L with 480 trans or 350 with 400 trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2013, 09:32 PM
Which motor is best for 55 chevy truck? Plessers tell me why I have asked and been told Many things.
Old 08-18-2013, 09:55 PM
Proud LOSER
Communication is a rare commodity these days.
Your asking us if you prefer peanut butter or jam.
How the hell do we know what you want.
The LQ4/4L80 combo is excellent
The 350/TH400 is excellent.
What's the usage?
What's your budget
What's your skill level
Let's start there.
Old 08-18-2013, 10:10 PM
Better engine and trans
Thank you so much for righting my head. Skill level is weak but have great help. 8 grand is my budget
Old 08-18-2013, 10:28 PM
350 and 400 trans would be cheaper, easier and probly just as reliable if not more reliable.
Old 08-18-2013, 10:34 PM
A basic stock rebuild the 350/400 is going to be cheaper. The 350/400 is going to be easier. I'm really not up to speed on the exact cost of building a 6.0/480 but that should be enough to build a 6.0/480 that will out perform the 350/400 in every catagory including better milage. You're comparing nearly 60 year old technology to 15 year old technology. If I had 8,000 to get the job done I'd go with the 6.0 and you'll probably have change left over.
Old 08-19-2013, 12:23 AM
Proud LOSER
Is 8k the entire vehicle budget? Or strictly motor and trans?
Old 08-19-2013, 06:26 AM
vinniekq2's Avatar
The LS engine has a very good fuel management system and ignition system from the factory. The LS cylinder heads have decent flow from the factory.
If you built a 350 with a roller cam/fuel injection/crank fired ignition,you would have virtually the same thing.
If you build both engines factory stock,then the LS engine has a roller cam,fuel injection and better ignition and cylinder head flow.
Old 08-19-2013, 07:28 AM
RWENUTS's Avatar
Skill level guys! He's admitted to weak skill level!
A 350 turbo 400 combo will be more than he can handle let alone getting into the complexities of a newer computer controlled motor/tranny.
Old 08-19-2013, 12:23 PM
Proud LOSER
Depending on how "weak" here is your solution in your budget
http://www.summitracing.com/parts/ml...make/chevrolet
http://www.summitracing.com/parts/hup-34-1/overview/
trans swap, 400 trans in 83 elcamino? renagade Transmission - Rearend 2 10-07-2011 09:45 AM
stock 5 speed trans. with a 400 hp 350 Camarorider Transmission - Rearend 11 07-26-2011 10:55 AM
Chevy 350 to 400 trans combo Rockey Meo General Rodding Tech 5 09-14-2006 02:46 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
350 trans bolt to a 400 engine. greg67 Engine 2 11-05-2003 11:27 PM
