Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 6 to 12 volt
Thread: 6 to 12 volt
Old 06-16-2004, 12:10 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
You MUST run a voltage regulator. If you used the typical GM alternator with the internal regulator, you won't need an external one. If you used a Chrysler or Ford that require an external regulator, then use one.
