6 to 12v conv - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2006, 01:43 PM
Southern Man
6 to 12v conv
I have a 49 f1 that I am slowly but surely changing to 12v, I was told I had to put a power reducer to the dist. cause it will burn out my points w/ 12v, I've changed everything else related to the conv. I even found a 12v starter from LMC Truck that will fit a flathead, for $299. seems to be a good deal, I haven't ordered it yet cause I just found out about it. could someone tell me anything about the dist. thanks JOJO
Old 08-16-2006, 05:38 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Did you upgrade the coil to 12 volts yet?
If so get a standard Ballast Resistor and hook it up between the Ignition wire, and the + side of the coil..
Do not mount it (the Ballast) on the coil, It heats very hot, and will shorten the life of the coil..Mount it on a metal surface that is free of fuel and petroleum lines and can not catch fire to anything AND where you won't accidentally rest your arm on it..( )
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
6v To 12v? jogunne Electrical 1 05-24-2006 03:45 PM
Spacers behind fan? moodier General Rodding Tech 14 10-06-2005 08:08 AM
6v to 12v conversion Nightfire Hotrodding Basics 4 08-12-2004 12:52 PM
6v to 12v ? HELP ! 1235675 Electrical 2 11-25-2002 05:04 PM
71 chevelle conv will Hotrodders' Lounge 2 12-12-2001 01:27 PM
