6.2/350 swap trans question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2011, 07:42 PM
I have an 89 suburban with a 6.2 and od trans. The 6.2 is very tired so I want to replace it with an older carburated 350. Do I need to be worried about the electronics for the tranny?
Old 09-27-2011, 07:58 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Does the vehicle have the over drive 4 speed trans or the 3 speed trans?
You will need to change the diesel torque converter to a gas version for the proper stall speed rating
Old 09-27-2011, 08:02 PM
Three speed with od... I think? Havent driven it much because it wont hardly get out of its own way!
Old 09-27-2011, 08:06 PM
Sorry, I just read your post again. Its the 4 speed. 3+1=4.
Old 09-27-2011, 08:09 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The trans would be a 4 speed over drive trans like a 700-r4 or a t-400 trans which is a 3 speed.
Best figure out what you have first.
What does the shifter indicator look like?
PRND21 or PRN-OD-D21 or PRND321 ?
Old 09-27-2011, 08:12 PM
P R N Od D 21
Old 09-28-2011, 01:39 AM
SSedan64's Avatar
Should be a TH700R4/4L60 Trans. As 'Crosley' said above, you'll need a Gas engine TC/TorqueConverter.
I'm not sure about the Trans wiring for the TC's Lockup clutch when going from Diesel to Gas engine. 'Crosley' may know what Sensors etc.. and if ECM controls Lockup with Diesel.
This shows Basic TCC plug wiring diagram>> http://www.hughesperformance.com/pdfs/HP700-R4.pdf
Old 09-28-2011, 05:24 PM
Thanks for the info. I plan on doing away with as much of the computer stuff as I can and just want to make sure the trans will still work right.
Trans swap question RustyRatRod Transmission - Rearend 1 11-28-2008 01:51 PM
61 Cad trans swap? BadA$$37 Transmission - Rearend 1 06-22-2006 09:35 PM
trans swap laserline350 Transmission - Rearend 5 01-14-2005 10:55 PM
trans swap firefighter3516 Transmission - Rearend 1 11-20-2004 06:50 AM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
