6.2 Diesel to 350 swap "Trans" Questions? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-20-2011, 11:27 AM
Irelands child's Avatar
30 years later - not a clue .
My thinking and opinion only - you had best use a gas engine tranny. Modulators as mentioned previously and torque converters are probably different as well as possibly the internal valving.
B-O-P = Buick-Oldsmobile-Pontiac. Many of us here tend to use acronyms that confuse others. Sorry
Dave W
Irelands child
  #17 (permalink)
Old 05-20-2011, 11:40 AM
There's about a million threads out there, including on here that claim the TH400 will bolt directly to a 350 and or a big block since they share the same bolt pattern. I was told the only swapping necessary is the converter and the gov. The gov.only was mentioned because it controls the shift points and since the diesel shifts at a lower RPM, that's the reasoning for the swap on that, which may not be necessary. Other than those 2 items, the transmission is identical. The majority of information I've found on this swap came from this site. Here's just one of the many. 6.2 Diesel swap to 350 gas
  #18 (permalink)
Old 05-20-2011, 12:04 PM
I should mention as well, that the 6.2 liter is not in anyway related to the Olds motor. This is from all the information I've found pertaining to it. The 6.2 liter in the 83 Chevy's is a Detroit diesel. The same as used in the military Humvee. A lot of people get them confused. The 6.2 is basically a 350 base, with diesel heads and a heavy duty rotating assembly in it. I find about 50 50 on these motors. Half like them, half don't. I weighed my options and I believe this is the best route for me to go. My motor was garbage, Heads garbage, & Diesel currently $4.39 a gallon. If you compare the mileage vs. cost of fuel, I think it's about the same either way. We have a Cummins diesel and hardly ever drive it because of the fuel cost.
  #19 (permalink)
Old 05-20-2011, 04:40 PM
Altec's Avatar
Bottle Of Whiskey
The 5.7L diesel was a BOP. The 6.2/6.5 is GM, and uses a GM bell housing.
A 6.2/6.5 uses a weighted fly wheel, where as a 350 does not. So that kills the use of a 6.2 wheel, on a 350 right there. I swear I remember the crank pattern being the same though... Not that it matters. Like said though, a 350 6-bolt flex plate is what you need with a tooth count to match the starter setup.
The 6.2/6.5 uses a 1500 stall converter. I believe the lowest gasser 400 stall was like 1800?
Frodin- "The 6.2 is basically a 350 base," That is not true at all. Nor is the 5.7 based on a 350.
  #20 (permalink)
Old 05-20-2011, 05:52 PM
I meant as far as the bolt patterns go, like I had said before. The 350 and 6.2 are very different motors when you look at them taken apart. I just sold a bunch of stuff out of the 6.2 and they are VERY different inside. For 1, I've never seen a 2 piece 350 come with roller lifters from the factory? They are way different as far as strength goes. Of course, I've never seen a set of heads so beaten down until I took this diesel apart either. Just a note to those who do this! Running straight water in an engine is evil, and unless you want a whole handful of issues in the future never do it. Antifreeze is for more than just cooling. Cracked heads and valves on both sides, heavy rust though out the motor, freeze plugs leaking, corrosion eating it's way through to the internal trans cooler and filling the transmission with water. These are all things that WILL happen if you do this. Spend the $10 bucks and put the right stuff in your radiator. Please! Lol
  #21 (permalink)
Old 05-20-2011, 10:39 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Chevy diesels have the same bolt pattern as Chevy gas engines. You can even bolt your TH400 behind a duramax if you don't mind missing the extra bolt holes that the duramax has on the oil pan.
The early chevy truck diesels (before the 6.2/6.5) were the Olds 5.7 diesel, which has the BOP housing pattern.
But, regardless of diesel or gas, every GM passenger vehicle since about 1963 came off the line with either a Chevy or BOP bellhousing pattern.
  #22 (permalink)
Old 05-20-2011, 11:17 PM
Thank you!
  #23 (permalink)
Old 05-26-2011, 09:56 PM
Nailhead2x4's Avatar
I've been driving this stuff for years and still do. The 6.2 block will mate with chev turbo 350, 400, 700R4. My 81 5.7 diesel , these trucks came with a dual patterm 350C tranny meaning it will bolt to the olds block or the chevy block, which was neat cause if you blew up the olds diesel then you could throw in a olds gas or a chevy gas if you wanted. It will work ok if you just bolt your gas 350 to that diesel tranny just use a gas flywheel. That 6.2 is fantastic on fuel especially with the o/d tranny and is far cheaper to run than any gas motor, too bad yours is done.
...I'm just an old rock 'n roll Hot Rodder...
  #24 (permalink)
Old 05-26-2011, 10:20 PM
Yea, I weighed the options, and I seriously tried to save her. But after I did a compression test, and pulled the head and found a busted valve I figured it's time to retire it. I ever looked into getting a military 6.2 off ebay, to put into it, but they want an arm and a leg "or two" for those diesels. Kind of a bummer, but oh well, I gotta go with what's cheapest and available to me. Since I already had most the stuff for a gasser, I figured that would be the way to go. Thanks for the input!
  #25 (permalink)
Old 05-26-2011, 10:37 PM
I presume where you are there ain't many diesels in the salvage yards. Up here there are many so a guy can pick them up fairly cheap yet. Rare to break a valve but I bought one once with only 30K 6.2 that the guy said was just idling and bang ! , took it apart and broken valve . You can still use your hydraulic brake booster if you have the brackets to bolt the pump to the gas, remember the diesel ps pump puts out more cause of the brake booster than just a reg gas ps pump. Unless you go to a vacuum booster then it doesn't matter on the ps pump. Otherwise not a big job to swap.
  #26 (permalink)
Old 05-27-2011, 12:44 AM
Yea, A lot of the yards have started disappearing out here. They crush everything and move on. It's sad actually, they're in a way eliminating a hobby for many people. Its all about the mighty buck. I still do have everything for the diesel, so I do plan on using the PS pump. If anybody knows this, it would help me out. What's the difference between the Diesel fuel pump and regular gas? I purchased a brand new electric pump, ran it for about 5 minutes and shut it down before I took the motor out. I'm just wondering if I can still use it for the regular fuel without anything catching fire or blowing up? The pressure is rated 14psi max. I was planing on using a 600CFM 4 barrel? I figured I could just use a regulator if it's to high for it? What do you think?
1956 OLDS"98" trans swap questions gsuperdave1 Transmission - Rearend 5 10-31-2010 10:31 AM
Tranny and engine swap questions...."1990 caprice classic"th400 vs 67' muncie 4 speed 74chevyflat Engine 5 02-10-2007 10:28 PM
1987 Burb, 6.2 Diesel.. "start engine" light dont work boneyard Buick Engine 3 10-09-2006 06:41 PM
51 Pontiac "8" trans swap Boogie Woogie Transmission - Rearend 2 05-15-2006 12:11 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 02:13 PM
