6.5 diesal 350 sbc swap ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2008, 09:03 PM
i have a 1995 gmc sierra / old state vdot truck/ 165000 miles runs excellent except ,a dead miss that might get very expensive,, anyway,,how much trouble to put in a350 sbc. ??will it bolt right in /motor mounts/?? can i use same torque converter and tranny?? its, a700r4 i presume ,3 spd.with overdrive in a half ton truck,, i presume i,ll need a wiring harness too . i thank you all for your expert advice..rick
Old 09-19-2008, 09:29 PM
does it need to go through emission's test ?
Old 09-19-2008, 09:34 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I'd have to imagine the diesel got a 4L80E. I might be wrong but a 700R4/4L60 might be a little on the weak side.
Old 09-19-2008, 10:13 PM
thanks, i can slide thru the emissions ,, and it could be a 4l 80e /trans pan is square like a 350 turbo ,,and it will power spin both whells on concrete bridges big time ,,any way i want all that computer junk out complety ,it even has a computer on the throttle , but the 350 sbc is in a 1979 gmc with hei ignition, mainly i justwant the ignition to work ,, or i can rig my own under dash if i have to i want to strip out everything that i can and and have clean engine bay with a 350 ,thanks,
Old 09-19-2008, 10:46 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
The 4L80E will not run without a computer, period. But there is good news... I'll get to it in a minute.
The 6.2/6.5 family of engines was designed to basically bolt in place of any chevy engine, so the SBC swap should be a super easy breeze. Just confirm that the motor mounts are the same (or buy the proper mounts) and drop it in place. The bellhousing bolt patterns are the same. Two things you'll want to consider; 1) the diesel typically uses the large bolt pattern on the torque converter, so you'll probably need the larger (168-tooth) flexplate on the SBC. and 2) the diesel torque converter is a low-stall unit that won't be optimized for a gas engine. It will physically work, but it might seem a little sluggish off the line. For that reason you might want to get a stall that is properly matched to your 350
The good news I promised... Hotrodders for years have tried to find cheap easy ways of gettting a 4L80E to work in their old cars. One of the ways they have discovered is to use the computer from a 6.5 diesel. It has to be modified internally somehow, but do a search on some diesel forums and you'll find that the diesel PCM is one of the ways to get a 4L80E to work behind an old-school engine. I don't know the details, but someone in the tranny forum might.
But... I'll say it again, because I know your next question is going to be, "can't I just shift it manually?" or "how can I get it to work without the computer?" You can't. Period. The only thing you can do is install a race-type manual valve body along with some other modifications and then shift it manually.
Old 09-20-2008, 10:54 AM
To add a little detail to Curtis73, you will see on the driver side of a 4L80E trans a little shaft poking out, on which a shifter linkage is connected/can be connected. You cannot just connect your truck shifter to this shaft to run the trans, it will not work: this shaft is just a switch, allowing you (with your traditional shifter) to tell the computer in which gear you want to be; the actual gear shifting is then done by the computer, inside the trans.
Old 09-20-2008, 11:52 AM
Blazin72's Avatar
Wiki Edits: 19
If needed, there are also aftermarket transmission controllers. They aren't cheap though.
http://store.summitracing.com/partde...5&autoview=sku
Old 09-20-2008, 09:23 PM
thanks,, everybody for your replies and great advice, i think i,ll stick a 350 turbo in it , modify driveshaft ,,a floor shifter and keep things simpler,, and less expensive , thanks again FOR YOUR TIME
305 head on a 350 sbc Trav Engine 41 04-13-2013 09:30 AM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
SBC Strokers - 350 vs 400 Blocks & Combos (not just 383 & 406) ez2cdave Engine 11 05-21-2007 10:34 PM
cHEV 4.3L Bore size..compare to SBC 350 (both stock) boneyard Buick Engine 5 09-25-2006 08:29 PM
350 to 305 engine swap jrm123180 Engine 10 03-28-2004 05:03 PM
