6.5 turbo - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2012, 04:54 PM
6.5 turbo
I have a 98 chevy 2500 with the 6.5 diesel. I have no power and it smokes black smoke whenever I accelerate. I checked the turbo it seems fine. I read that if I can move the waste gate linkage while its running something isn't right. So I can move it while its running. What does this mean?
Old 06-11-2012, 05:55 PM
I just got looking at it and the vacuum line going to the waste gate actuator had a hole in it. I patched it up and it didn't seem to fix anything. I could still move the linkage while it was running. I tried tying the waste gate shut and it seemed to make a difference but I didn't want to run it too hard
Old 06-11-2012, 07:08 PM
S10 Racer's Avatar
http://www.warsprints.com
The turbo is controlled by the vacuum operated waste gate. At an idle, you should be able to unplug the vacuum line to the turbo waste gate actuator. If the actuator releases and the vacuum is present at the line, I would install a new waste gate control solenoid, which should be on the driver side of the engine. If you have no vacuum when the line is removed you may have a bad vacuum pump or a bad line.
Old 06-12-2012, 09:35 AM
boatbob2
6.5 Diesel
Hi,go to the DIESEL PLACE.Com,click on 6.5 diesel,MUCH more info than you need....
turbo 350 and turbo 350c riley81GMC Transmission - Rearend 6 12-12-2009 08:07 PM
Thrush Turbo or Dynomax Super Turbo? henkelphoto Engine 3 08-24-2006 11:46 PM
350 turbo to 400 turbo swap in lemans?? mtmniles Transmission - Rearend 8 01-24-2006 12:40 AM
Turbo 350,Turbo 400,700R4,Or Muncie 4 Speed nightrain_rod Transmission - Rearend 2 04-18-2003 12:35 PM
400 turbo to 350 turbo problems mikeweyman Transmission - Rearend 2 04-02-2003 05:58 PM
