6-71 BDS Supercharger Basics - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2008, 10:54 PM
Okay! I'm presently working on a Blown Mouse-Motor buildup and have purchased the forged bottom end required for this venture. Forged as in crank, rods, and inverted dome blower/nos pistons. The specifics are purposely left out now because my question involves the forced induction.
I have a 6-71 BDS Supercharger that has been modified and clearanced for street gas usage with double pinning, .007 rotor clearance, and no Teflon. My choice there. All new bearings and gears. A new 3 7/8 inch snout. Now comes my dilemma. The drive pulleys. I'v decided to run a 3 inch belt at 1/2 inch spacing. I prefer this old school over the 8mm. Really, for street, it doesn't really make much difference. Determining my under drive is fairly straight forward and yet I'm baffled.
My question: For this street buildup to work, I need to determine my boost. At 93 octane pump gas availability, I want to keep the boost at approx. 7 to 8 lbs max. There are so many factors at work here with head cc's, stroke, compression, cam, and on and on. What I need is a rough idea of the way to calculate boost based on the drive pulley teeth and/or ratio with this 6-71. Any ideas???? Can I base it on % underdrive?
Old 10-21-2008, 09:10 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Moving to the Engine forum
Old 10-21-2008, 09:14 AM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
I have a Wieand 6-71 on a mouse and it will make 10 lbs of boost. I just run pump 93 octane with no problems. The drive is 12% under for the street. I do run the MSD boost retard box.
Old 10-21-2008, 10:27 AM
XNTRCI-T's Avatar
AKA Lee in KC
Maybe these charts on BDS's site will help.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
Has anyone priced the BDS supercharger for the LS? Ouch!!!! Stovebolter Engine 11 08-27-2008 02:59 PM
4 -71 supercharger grapro Engine 6 04-11-2008 02:12 PM
Possible/worth it? 3.8L supercharger on 305 chevy Project87c10 Engine 9 12-20-2004 08:44 PM
supercharger problem mad van Engine 1 06-23-2002 11:42 AM
