6-71 blower 383 build - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2007, 07:49 PM
hi whats up uys ive got a 350 4 bolt main block,(383) eagle rotating assembly from cnc motorsports for forced induction engines, forged non twist steel crank, h-beam rods je pistons 8.5:1 compression with 64 cc chambers i havent purchased heads camshaft or carbs yet, what are your ideas guy?,this will be street driven but rarely, not more than 10 miles at a time, im leaning towards a flat tappet cam, does comp have something in their selection or should i have one custom ground? as far as cylinder heads i like the dart pro 1's would 215's or 230's be better? 64 or 72 chambers? (compression with 72 is 7.8:1) what about carbs? what is my power potential while keeping fairly good street manners? i am in the very early stages of this project any advice would be helpful, thanks.
Old 07-18-2007, 07:58 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
I have a very similar engine in my T bucket. I used 2 1405 Edelbrock carbs and Summit hyd cam. The engine idles at about 1000 rpm and has plenty of power.
http://store.summitracing.com/partde...7&autoview=sku
Old 07-18-2007, 08:04 PM
Dart makes good heads, but before you buy, look at rhs heads, they make very good iron and alum. heads, that will run dead nuts to any of darts heads, at a lower price. As for a cam, I would call comp and talk to a tech guy, that way he can come up with a grind taylored to you application. Half the time they reccommend a cam right out of the catalogue.
Old 07-18-2007, 08:38 PM
The Revolution Begins !!!
The New Freedom Series SBC & SBF Heads by Patriot Performance !!!
Freedom Series SBC 23 Degree Heads
Aluminum Heads...at Iron Prices !!
190cc CNC Bowl Blended and Gasket Matched
2.02"/1.60" 1-Piece Stainless Valves
.575" Hyd. Flat Tappet Springs (will work on smaller Hyd Roller cams)
3/8" Studs and Guide Plates
Steel Retainers
These heads offer exceptional quality at an unbelievable value !!
MSRP
2180
SBC 190cc Freedom Series 2.02"/1.60"/64cc Assy Angle Plug
$795.00 Pair
2181
SBC 190cc Freedom Series 2.02"/1.60"/64cc Assy Straight Plug
$795.00 Pair
http://www.patriot-performance.com/w...p?x=1&DID=1225
Car Craft tested them and they perform with (within 3 hp) vortecs modified for higher lift and screw in studs
Shane
Old 07-19-2007, 07:07 AM
RPM's Avatar
RPM RPM is offline
Steel Retainers
MSRP
2180
$795.00 Pair
2181
$795.00 Pair
Shane
Yes I forgot to mention the heads.... Here are the heads I have.
http://cgi.ebay.com/ebaymotors/PATRI...mZ260139061388
Old 07-19-2007, 08:06 PM
well ive been reading up on my "secrets to street supercharging" book and ive also seen it many many times on here, i think im going to send my 6-71 and go with an 8-71 (less heat and wont have to spin it as much) which leads me to my next questions does anyone know anythng about these guys? http://www.dyersblowers.com/1694.html pretty good prices but i know you "get what you pay for" sorry for the ongoing questions but i want to get this right the first time
Old 07-20-2007, 06:41 AM
bentwings's Avatar
bentwings
Dyers make a very blower kit. I used several and had good luck with all of them. Hard to beat. Price is pretty reasonable too.
I use the whole kit unless you've done this before. He has the carbs setup for the blower so you only have to do some minor tuning.
6-71 is plenty for a SBC.
If you have E-85 available consider setting it up for this as it is about 105 octane rating or better and $2.45 per gallon.
This guy does a great job onthe conversion. I wish you could see his blown Nova. It runs so good you can hardly tell it is blown.
http://www.e85carbs.com/index.htm
383 build "help" slow'n'steady Engine 13 11-26-2006 08:09 PM
11.0:1 CPR 383 Stroker Build Optik Engine 3 03-26-2006 08:54 PM
383 build up went wrong? please HELP!? fireforsin Engine 19 03-07-2005 10:19 AM
Received my quote to build up a 383 TCAMARO Engine 25 01-07-2005 05:26 PM
need cam suggestions for my 383 build TCAMARO Engine 10 12-23-2004 04:51 PM
