6-71 vs 8-71 blowers - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2008, 02:32 PM
i need to no if i should use an 8-71 or 6-71 blower on my 68 gto's 400 cui engine
Old 07-17-2008, 04:19 PM
41willys's Avatar
Blowin' it
Last journal entry: Running again...
Wiki Edits: 11
A 6-71 would do just fine for street use.
Have you decided what brand blower you are going to go with? You could always call BDS and give them your specs, and what you want out of it, they will tell you what would work best for you.
Jason
Old 07-17-2008, 08:38 PM
8-71 blown 461 Rat on E85
A roots type 6-71 over 400 cid will be fine for a street deal with a driver frendly blower cam and stock flowing heads.If you build the engine with a big stick and honking cyl heads..the additional cfm the 8/71 delivers will allow you to underdrive the unit vs the 6/71 and reduce intake charge temp and ward off detonation issues.
Old 07-18-2008, 07:57 AM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys is Finished!
Wiki Edits: 2
I went with an 8-71 on my 392 Hemi exactly for the reason stated above.
Steve
Old 07-18-2008, 04:06 PM
BORTI's Avatar
BLOWN 357
6-71 Or 8-71
Steve
I went with an 8-71 as well,turn it slower making the same boost,and less heat.
Old 07-18-2008, 04:58 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Take a look at the new Popular Hot Rodding issue on the newsstands, there is an excellent article on blowers and recommendation in this months issue. Good reading!
71 C10 long box to short tumbleweed1 General Rodding Tech 9 07-16-2007 04:28 PM
'71 Gmc 2500 mercflathead Engine 16 01-08-2007 10:55 AM
Got a ? about the Weiand Pro street blowers Streetmaster Engine 3 10-27-2005 10:58 AM
Big Block 71 Nova Swap RObs71Nova Engine 7 10-14-2004 01:31 AM
