6 banger rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2003, 01:34 PM
mustangman1968's Avatar
speed secret: drive fast!!!!!!
6 banger rearend
i got a 68 stang with a 6 cyl rear im planing on putting somthing a little more beefy like a 9" but i already got a good set of rims i have heard of custom axels but what a bout the brakes has anyone did a simalar swap what did u have to do some help please
Old 12-03-2003, 12:59 AM
billman's Avatar
Going from your stock 8 inch to a 9 inch should be a bolt-in swap from any '67 thru '69 Mustang or Fairlane. As far as the wheels, those may have to go, or run an adaptor plate. The interference will be to the inside of the fenderwell then, not the backing plate. The drum brakes on the 9 inch should work on your car fine.
Good luck.
