6 cyl to v 8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2012, 08:43 PM
6 cyl to v 8
ok I have decided to scrap the in line 6 in my 54 belair and go with a 350 where can I get the mounts to convert this project ? want it done right is there a kit that is made and if so who makes it ...thanks
Old 09-13-2012, 03:04 AM
Motor Mounts
Hi Superdc,
You might want to check out Chassis Engineering in West Branch, IA.
Their website is www.chassisengineeringinc.com You may have to do a little searching on their site, but if I remember correctly, they have a kit specific for your application. I'm sure that other companies have kits as well, You just have to do a little "Googling".
P.S. Chassis Engineering is one of those outfits that have been around forever. Hope that helps. Rick
The Following User Says Thank You to F1 Owner For This Useful Post:
superdc62 (09-13-2012)
Old 09-13-2012, 06:09 AM
6 cylinder to V-8 engine swap
Here is another company that sells engine and transmission mounts for your engine swap. 1949-54 CHEVY CARS
The Following User Says Thank You to cdminter59 For This Useful Post:
Old 09-13-2012, 07:39 AM
Wiki Edits: 27
rear end too !
It doesn't end, You will probably want to change out the old torque tube rear end to something newer, need rear spring index pin relocater or new springs, then front disc brakes, power steering, then power windows and door locks. A/C then have a new car in an old body. We started on My 100 year old farm house where we spend the winters when we go south. , Just going to fix the leak in the back porch, some new paint, and refinish the original oak floors, Ended up an entirely new roof, replacing the 80 year old wiring and plumbing, adding insulation, new windows, new kitchen cabinets, tile bathroon, etc.. etc.
Old 09-13-2012, 09:13 AM
Wiki Edits: 31
Dont scrap the '54 engine, it's worth a few bucks to someone wanting to switch out a babbit pounder 216/235 with a FPO 235. '53-'54 are the only engines that fit without a water pump adapter, and the only engines that appear stock in those same cars.
Several places sells the SBC mounts.. Chevsofthe40s and National Chevy assoc both come to mind also.
6 to v 8
4 Cyl T5 Mac88 Transmission - Rearend 2 07-03-2011 06:27 PM
pontiac 6 cyl. andrew hassler Engine 3 09-03-2010 08:36 PM
Any 4 or 6 cyl projects? Blackdog Hotrodders' Lounge 32 01-04-2006 10:46 PM
Wp Cyl. Heads GRAVOIS Engine 0 06-29-2003 07:35 PM
Newbie help: 4 cyl vs. V-8 manofsteel Hotrodders' Lounge 2 10-29-2002 06:25 AM
