6 cylinder? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2005, 10:30 PM
Unkl_Bnz's Avatar
Amateur Bodyman
6 cylinder?
Ive got a 67 Mustang that has a straight-6 200 cubic inch engine in it which is just to small... i wanna go up to an 8 but my insurance company said if i do its gonna add like 300 or more to my insurance (ive got way to many speeding tickets) so i wanna know whats the best 6 cylinder ford makes that i could build into a decent streetrod?
Old 12-20-2005, 10:42 PM
Sixpac's Avatar
Six
You could make the 200 run pretty good with some basics...intake, dual carbs and headers. If you had some head work done and a light cam it could be a little sleeper.
Here's an example...follow this link http://falconperformance.sundog.net/gallery.asp
This is Phil Clements warmed up 200. It has a Clifford dual outlet header, CompCams 260 bumpstick, DuraSpark II conversion, Jacob's Ultra Coil and 8.5mm wires, topped with a Holley-Weber 5200 on a Clifford adapter.
Old 12-20-2005, 10:46 PM
Unkl_Bnz's Avatar
Amateur Bodyman
how exactly do you set up duel carbs? ive seen it done quite a bit but i never really took the time to understand how it worked?
also what would a good carb be? ive still got the stock single chamber on mine...
any suggestions as products that would work good? or even places to check? ive had a difficult time finding parts for my motor which was my original reasoning behind changing it
Old 12-20-2005, 10:49 PM
TechnTool's Avatar
OldSchool MotorHead
That 6 cyl is good for at least 200HP, and you won't blow it apart. I would go for upgrading the 6, becasue it can give you better low end torque than a v-8, being an inline. Try Dallas Mustangs for parts, they are in Dalla Texas.
Old 12-20-2005, 10:52 PM
Sixpac's Avatar
You might try the link fordsix.com
I had dual carbs on my truck, but it wsa 230 Chevy six cylinder. It just incolves a dual carb intake (bolt on) and the correct linkage. It is best to match the cam, carb and all together rather than piecmilling it.
I'll send you pics of my six with the dual carbs and also with one 390 Holley four barrel if you want.
Old 12-20-2005, 10:57 PM
Unkl_Bnz's Avatar
Amateur Bodyman
do you know if dallas mustang is online at all? im in virginia i cant exactly take a trip to dallas for car parts...
Old 12-20-2005, 10:59 PM
Sixpac's Avatar
They're online, we buy parts for our 95 GT there al the time. Great quality.
There catalog is easier to follow. They'llsend you one, and then look up your parts online after looking thru the catalog.
http://www.dallasmustang.com/
Old 12-20-2005, 11:03 PM
Unkl_Bnz's Avatar
Amateur Bodyman
sixpac id love to see the picture of your carbs.. it might help me understand it better
and im guessing with something like tha tim gonna need something like a cowl induction hood for the extra clearance?
Old 12-20-2005, 11:13 PM
Sixpac's Avatar
Not if your intake is side mounted like I think it is....
Old 12-21-2005, 08:12 AM
357f-150's Avatar
Unkl Bnz
Sent you a private message
Old 12-21-2005, 08:58 AM
Unkl_Bnz's Avatar
Amateur Bodyman
thanksa lot... it actually looks like some of those were tri-carbed
Old 12-21-2005, 04:32 PM
Wiki Edits: 31
The '66 up 200 is a rock solid motor, 7 bolt mains and 2 bolts per cap, the problem with the small six, is that it does not breathe well. There is an issue with putting on a intake manifold, that is it has a integral mounted intake manifold ( cast right on head ) so cutting and welding would be nessary, not just a bolt on, but running the Holley/ webber 5200 off a clifford adaptor will work nice but suffer, another option ( though pricey ) is to get an OZ 250 2v head ( which is the aussie version of the 200-250 I6 head, bolts on, removable intake, everything is bolt up ) there are places that sell them on Ebay, or Fordsix is going to be releasing a aluminum head for the motor. a light cam, the OZ head and a set of dual outlet headders ( FSPP has really good prices on them ) and it would be pretty quick, hook up a granada -monarch 4spd ( cheap version of toploader ) and you would have a pretty quick car, and with a set of chambered mufflers, would sound almost like a V8
visit www.tffn.net for other options and also www.fordsix.com
Old 12-21-2005, 06:35 PM
onebadmerc's Avatar
I need a bucket of arc sparks
If you have no experience with multi carb setups I would steer you clear on doing it. A 500cfm Holley 2 barrel carb would be plenty on a 200 six. The next best thing you can do for your 200 is to put on a header and run dual exhaust. I would then convert it to electronic ignition off of a mid to late 70's 250 inline six so it has plenty of spark. If you really want to add some Hp and Tq, find a 170 head, install 250 valves, bowl blend it and bolt yourself a 500 cfm Holley on top of it and let it rip.
Old 12-21-2005, 07:57 PM
Wiki Edits: 31
Originally Posted by onebadmerc
If you have no experience with multi carb setups I would steer you clear on doing it. A 500cfm Holley 2 barrel carb would be plenty on a 200 six. The next best thing you can do for your 200 is to put on a header and run dual exhaust. I would then convert it to electronic ignition off of a mid to late 70's 250 inline six so it has plenty of spark. If you really want to add some Hp and Tq, find a 170 head, install 250 valves, bowl blend it and bolt you 500 cfm Holley on top of it and let it rip.
The pertonix ignititor kits do the same thing as the duraspark II electronics, but is easier and cheaper.
Old 12-21-2005, 09:11 PM
Unkl_Bnz's Avatar
Amateur Bodyman
wow i need to work on understand car lingo better... im still slowly learning about motors as i work on mine so i kinda only understood half of the stuff you just said... hahaaa
Theory: Intake volume vs cylinder volume / engine vacuum 59vette Engine 6 04-29-2004 12:03 PM
Help with continuing master cylinder problem chris57 Suspension - Brakes - Steering 3 09-30-2003 02:35 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
Bleeding Wheel cylinder on a 91 corolla ramvrao Suspension - Brakes - Steering 1 03-20-2003 03:38 PM
chevy 305 cylinder relined DADDYBLUE Engine 4 02-13-2003 05:56 PM
