6 Lug chevy p/u - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2013, 09:09 PM
6 Lug chevy p/u
I have a 72 chevy p/u. It has 5 lug wheels. I am thinking about late model 6 lug wheels, is there a 6 lug disk brake rotor from chevy for it? or are they drum brakes only . I was thinking about getting a late model rear with 6 lugs, and changing the front rotors to 6 lug so I can run stock chevy 6 lug aluminum wheels. would this be a good idea? I like some of the stock 6 lug aluminum wheels. And I could change the rear axel to a factory limited slip in the 4-10 gear range out of a four wheel drive. As always THANKS for any advise.
Old 05-28-2013, 11:31 PM
Banned
the rear is easy 67-70 are 6 lug
the front you'll need the 6 lug optional disc brakes spindle on out.
it be easier to use the 5 lug pattern. as the 71-72 came with disc brakes..
5x5 Bolt Pattern Compatibility List
Here is a 5 on 5 bolt compatibility list that I have compiled for wheels or brakes. I still have to work out Jeep and Infinity/Nissan. Admin donno if this is FAQ material, but your welcome to do with it as you wish...
Note: 5x5 bolt pattern is also 5x127mm
BUICK LE SABRE, RIVIERA 64-87
BUICK Riviera 64-78
BUICK Roadmaster 91-98
BUICK ROADMASTER, ESTATE WAGON 90-96
CADILLAC Calais 68-85
CADILLAC Deville 68-84
CADILLAC Fleetwood 68-84, 86-98
CADILLAC Seville 77-79
CHEVROLET 1/2 TON BLAZER, JIMMY, SUB FULL SIZE 2X4 71-91
CHEVROLET 1/2 TON TRUCK ALL MODELS 2X4 67-87
CHEVROLET 1/2 TON TRUCK ALL MODELS 2X4 88-98
CHEVROLET 1500 Ton P/U (2WD) 88-98
CHEVROLET ALL 5-LUG HALF TON TRUCKS up to 99
CHEVROLET ASTRO/SAFARI 85-on
CHEVROLET Caprice 88-98
CHEVROLET CAPRICE CLASSIC 90-97
CHEVROLET IMPALA SS 94-99
CHEVROLET Suburban 1500 (2WD) 88-98
CHEVROLET TAHOE, YUKON 2X4 92-99
CHEVROLET VAN G-SERIES 1/2 TON 71-96
CHEVROLET WAGONS & HD models 55-95
CHRYSLER Imperial 67-70
FORD FULL SIZE (CUSTOM, GALAXIE, T-BIRD) 73-78
FORD Custom 73-78
FORD Galaxie 73-78
FORD LTD 73-78
FORD Thunderbird 72-76
GMC 1500 Ton P/U (2WD) 88-98
GMC Safari Van 1500 85-2002
GMC Suburban 1500 (2WD) 92-98
GMC Van 1500 88-99
GMC Yukon (2WD) 95-98
JEEP Grand Cherokee ALL MODELS 99-06
LINCOLN CONTINENTAL, MARK III 73-79
LINCOLN Versailles 73-77
MERCURY COUGAR 73-78
MERCURY Grand Marquis 73-78
MERCURY Marauder 73-78
MERCURY Meteor 73-78
MERCURY Montclair 73-78
MERCURY Park Lane 73-78
OLDSMOBILE ALL FULL SIZE 88, 98, RWD (W/403 ENG.) 64-92
Old 05-30-2013, 10:06 AM
chevymike's Avatar
For the front, using the stock spindles, your only option is aftermarket (ECE, CPP, etc.) front rotors as GM never made a 6 lug rotor for the '71-'87 spindle. For the rear, use any '63-'70 rear axle (I am assuming you have coil spring rear suspension) as this will be a direct bolt in with 6 lug.
On thing to keep in mind, the later 6 lug wheels typically have a smaller center bore and a lot of late model wheels will not fit the aftermarket 6 lug rotors due to the larger hubs. Same with the rear axle, the step sticking out of the drum (axle hub) is larger than later models.
Another thing, many later model wheels have a large positive offset that will cause the wheels to be pulled into the wheel wells and create clearance issues. Later model trucks had the track centerlines wider than early trucks.
I have been in the 60-72 truck world for almost 20 years and it's not too common to see people going from 5 lug to 6. Typically it's the other way around. Now this is a trick method of using factory GM rotors/parts but it takes a little parts swapping. If you use '63-'87 3/4 ton lower A arms, you can use spindles from a '92-'98 C1500 or Light Duty C2500 (these are 6 lug spindles) and use the similar year ball joints and either the factory 5 or 6 lug rotors. You use the similar years outer tie rod and an adapter adjuster that will allow it to connect to the earlier inner tie rod. This is about the only way to use factory parts to do this.
Good luck.
Chevy AD truck 6 lug to 5 lug chevy car pattern mark b Suspension - Brakes - Steering 4 08-30-2011 04:42 PM
what to do to change a 6 bolt lug to a 5 bolt lug pattern?(chevy) uneeksparke Transmission - Rearend 4 06-12-2011 04:10 PM
Mustang 4 lug conversion to 5 lug and bigger brakes 1931gt Suspension - Brakes - Steering 17 06-03-2011 07:44 AM
8 lug to 6 lug rims on chevy 3/4ton 3/4ton flathead Hotrodding Basics 1 03-06-2011 05:23 AM
converting 1938 chevrolet from 6 lug to 5 lug drums Junkadelic Suspension - Brakes - Steering 2 09-27-2005 05:36 AM
