6 lug ten bolt? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2011, 10:41 AM
Last wiki edit: Mounting an electric fuel pump Last photo:
6 lug ten bolt?
i have recently broke the factory ten bolt that was in my 86 c10. it was a 2.73 ratio, five lug with the g80 locker. i called a friend and found a nother ten bolt. he told me it was from a 85 k10. its a six lug ten bolt, 3.08 ratio with open diff. i payed $100 for it and its a little chewed up on the inside but i need it to get to work. im just wondering if its a good deal and if maybe i should/could just pull and replace my broken axel with a good one out of the new one. i dont know if the spline is the same yet but what do u think???
Old 11-29-2011, 03:21 PM
SSedan64's Avatar
Doesn't sound like a good deal to me.
The Axle splines are the same but, I think the Axle length is different between 2X4 & 4X4.
Old 11-29-2011, 05:23 PM
Get this.
http://www.summitracing.com/parts/SAG-PA5694/
Old 11-30-2011, 09:18 AM
love that a new axel is almost exactly the same i payed for the used rear and gas... but its to late for that. i am having a problem getting the g80 apart tho. it locked up tight after it broke. i did have to drive the truck 5 miles home. id like to pull it apart and fix it one day. i tryed to remove the cross pin but its seems like its got pressire on it and dont wana move free enough to remove. i cant seem to release the pressure without a axel and cant reblace the axel without relesing the pressure
Better core block for sbc 383, 4-bolt flat or 2-bolt roller? Cousin_Joe Engine 24 02-08-2008 08:50 AM
questions about swapping R/E gears from a 12 bolt Gm into a Pontiac 10 bolt housing l Bad Rat Transmission - Rearend 6 06-11-2007 10:50 AM
Change 8 bolt front hubs/rotors to 6 bolt? (gm 3/4 ton) murrsue Suspension - Brakes - Steering 3 04-02-2007 01:05 PM
F-body differentials, 9 bolt Borg Warner vs. GM 10 bolt Mad Maggot Transmission - Rearend 8 02-17-2005 08:02 PM
2 bolt to 4 bolt swap and 2 bolt strength???? HemmiGremmie Engine 8 10-20-2002 03:06 PM
