Redrill the plate for the additional 3 holes. The six bolt converters were usually for bigger trucks/motor homes/diesel rigs. I don't think I'd just not not bolt them on, they may create a vibration/noise issue, and you'll be back under there again correcting it. Would they possibly exchange converters for you? You could also buy another flexplate already drilled for the six bolt converter.
6 Pad Converter
Dont Redrill Anything! Just Put The Three Bolts In It,u Wont Have Any Problems,and Yes The 6 Pad Is Just For High Output Torque
Converter bolt spacing
GM flex plates often have dual bolt spacing (6 bolt holes) to fit a torque converter with either a 11.50" and 10.75" bolt pad spacing. The TH350 and TH400 torque converters come with 3 bolt pads but may have either bolt spacings. If your flex plate only has 3 bolt holes and they don't fit the bolt spacing on your new torque converter, you will have to purchase a flexplate that has a dual bolt circle.
I went through this puzzle with my '91 S10 Blazer 4.3L V6 engine when I had the engine built with 350 Chevy forged pistons and internally balanced. The 4L60 (700-R4) transmission in my S10 Blazer use counter-weighted flex plates for externally balanced engines. When I had the engine built and internally balanced, I had to use a heavy duty (0.125" thick) 168 tooth flex-plate, 3" flange bolt circle for the one-piec e seal without a counter weight and was zero blanced. My engine builder knew exactly which HD flex plate to use. He provided an ATI #915534 non-counter weighted dual pattern flex-plate to use with a torque converter that has either a 10.75" and a 11.50" bolt circle, 168 tooth starter gear, a 3" crank flange bolt circle and zero blanced. Last edited by MouseFink; 02-14-2011 at 02:20 PM. Reason: typo |
Thanks everyone for the advice. I went with lovin's suggestion and just bolted it up with three bolts.
Maybe I'll find a powerplant that will justify the use of the dormant three pads down the road. So I guess, in hindsight, I'm glad I accidentally bought the 6 pad...one less thing to upgrade in the future! |
| Torque Converter to Flexplate Torque Spec. Needed - 2004R | Zeeb | Transmission - Rearend | 1 | 05-26-2010 06:47 AM |
| Bellhousing bolts and torque converter bolts torque specs | Davey3ch | Transmission - Rearend | 2 | 09-04-2009 11:05 AM |
| B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? | zbhover | Transmission - Rearend | 2 | 11-02-2008 07:52 PM |
| torque converter | jeepers creepers | Transmission - Rearend | 5 | 05-10-2008 11:03 AM |
| What torque converter is right? | Beginner | Transmission - Rearend | 1 | 10-08-2002 06:00 AM |
