6 quart oil pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2006, 09:23 AM
runn141's Avatar
SB S10
6 quart oil pan
im using a 6 quart moroso oil pan, should i just use 5 quarts so the oil will be farther away from the crank or not? im also using a diamond stripper windage tray and mellings 10552# 10% high volume oil pump
Old 12-22-2006, 12:21 PM
larryblack's Avatar
Certified Lead Foot
That is an old hot rodders trick. It really does not make noticable differences on most engines.
Fill the pan until the dipstick shows full. The scrapper is a nice touch to help get the oil back into the pan faster.
Chev 350 Oil Pan Gasket longt Engine 0 12-16-2005 09:04 PM
5.0 swap oil pan 5.0Falcon Engine 6 07-10-2004 05:22 PM
leaky oil pan .. where do i go from here ? chevyluvnpuppy Engine 11 09-12-2003 08:33 PM
ZZ4 Oil Pan Depth silvernblack Engine 2 06-11-2003 06:33 AM
Oil pan modifacation Jag Daddy Engine 10 05-03-2003 10:35 AM
