6" Rods in a 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2007, 02:32 PM
Mustangsaly's Avatar
6" Rods in a 350
whats everyones opinion on a 6" rod 350 ? what's the advantages & disadvantages of 6" rods in a 350 348 stroke ?
my plan is a SBC Build in the 6000RPM to 6500RPM Range, parts consist of a 350 roller block, Hyper pistons, GM Reconditioned I Beam Rods & GM Hot roller cam, Vortec Heads. 10.1 CR. the Dyno shows this setup (with 5.7 Rods) to yield a Hot Little pump gas friendly 350. this is a street thumper that will see a couple sundays a month during the race season on the 1/4 mi drag strip.
Displacement: 355 cu. in.
Carburetor: Speed Demon 750 and a 1 1/2 in. spacer
Heads: GM L31 Vortec
Intake: Edelbrock Super Victor single plane
Camshaft: GMPP HOT hydraulic roller, with 0.525/0.525 in. of lift and 218�/228� of duration @ 0.050 in. of lift.
Exhaust: Hooker 1 5/8 in. headers with Flowmaster 2 1/2 mufflers
Pistons: stock
Rods: stock
Crank: GM
Ignition: Stinger electronic with MSD 6
Timing: 32�
Comp. Ratio: 9.75:1
MAX HP: 422 @ 5700
MAX Torque: 418 @ 5000
Old 11-06-2007, 02:54 PM
King of my Man-cave.
Use whatever rod length the piston of your choice dictates. Your fanny will not be able to tell the difference between the two. BTW, I think you are a little over the edge for stock rods.
tom
Old 11-06-2007, 03:29 PM
so far I've been conservative on what I spent on parts, my 062 vortec heads are salvage yard specials that were off a low mi engine that were maged for cracks. the heads & block have to visit a machine shop yet, I figured I was pushing the stock rods but, thought I was safe with arp fasteners and a reconditioned rod. I keep thinking GM did it on the vette and a couple other SBCs. but I know this 350 is no good if it comes apart. so what rod would you recommend ?
this is going in a 74 Camaro with a 4 speed and 373s posi in a 10bolt that has aftermarket axles and a auburn limited slip with a bearing support cover and the axle tubes are welded. this rear might be a weak link also, I'm guessing the weak links are gona show up though.
so theres no advantages to 6" rods in a 350 ? if theres no advantages the 5.7 is prob a good choice. KB had a piston in the 10.1 CR Range for 5.7 rod & a 6" rod with a 348 stroke for about the same price.
thanks
Tom
Old 11-06-2007, 04:21 PM
We build a lot of engines and when ever we have the choice of going witha 6 inch rod over a 5.7 rod we choose the 6 inch every time, less cylinder wall friction more dwell time at TDC, lighter pistons and better results on the dyno.
Old 11-06-2007, 05:24 PM
This looks like a really good street motor. I strongly suggest you contact Demon to see what carb THEY recommend. My motor is much like yours and in talking to the BG tech here on Hotrodders, I got the distinct impression I was probably a little overcarbed. And my motor is a 383. If mine really was overcarbed, with my AFR heads and larger displacement, you will be for sure. The carb looks great on a Computer Dyno (DD or EA3) but all that's needed for carb tuning doesn't show up there. Barry Grant has the experts, their advice is free. I'd check it out.
Pat
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Any Machining Needed For 6" Rods In A SBC 400? NitrousJunkie Engine 2 06-27-2006 04:29 PM
5.7" vs 6" rods for sbc 406 tubaldave Engine 2 07-02-2004 07:17 AM
400 sbc 6" rods piston/crank clearance sutorcs Engine 2 07-06-2003 07:28 AM
