6" rods in a 350 sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2002, 01:42 AM
Post 6" rods in a 350 sbc
We all hear about putting 6" rods in a sbc 400,.. but has anyone used 6" rods in a 350 sbc? and what are the pro and cons of this setup? THANKS DY
Old 11-05-2002, 02:45 AM
Last journal entry: Doors
Post
I know it is done in race motors. but im not sure of the benifits
Old 11-05-2002, 04:46 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
I am actually building a 408 right now with 6 inch rods, but the idea is the same. You increase dwell time at tdc and decrease the rod angle. The dwell time helps with better combustion(this is in theory and I have never seen it proven on the dyno), and rod angle helps with engine stress at high rpm.
Chris
Old 11-05-2002, 10:34 AM
DoubleVision's Avatar
Post
Another known benefit of the longer rod is the higher rod ratio and the ability to run 11:1 compression on 87 octane fuel without detonation problems, They also have a much broader and flatter torque curve that standard lenth rods. Longer rods are always a good idea over the standard rods because of all the benefits. the late Henry "Smokey" Yunick`s theory was "run the longest Possible connecting rod you can fit in the engine"
Old 11-05-2002, 10:58 AM
bullheimer's Avatar
NEVER use credit cards!
Post
i cant imagine 11:1 on 92 octane let alone 87. i know newer cars are getting close due to computer controls, but i'm sure gonna see what develops on this post. i hope sommore engine builders put their $.02 in on this one to make it worth while
Old 11-05-2002, 12:20 PM
slider in wa's Avatar
Slider in Wa.
Post
I certainly had no idea you could run 11:1 compression on 87 octane. I will enjoy the out come of your post. I`m a shade tree guy, so some of you number crunchers jump in on this will ya? Slider in Wa.
Old 11-05-2002, 01:05 PM
Post
well i am getting a 383/w 6 inch rods built by the same guy that builds tony stewerts motors. I will be running 11:1 compression and this is what he told me. In winter 93 will be fine but when summer comes ill be pingging like a **** so ill have to add some racing fuel in.
now thats my 2cents THE END
Old 11-05-2002, 01:06 PM
Post
oh and heres the pros and cons
Longer Rod Pros
Less rod angularity
Higher wrist pin location
Helps resist detonation
A lighter reciprocating assembly
Reduced piston rock
Better leverage on the crank for a longer time
Less ignition timing is required
Allow slightly more compression to be used before detonation is a problem
Less average and peak piston velocity
Peak piston velocity is later in the down stroke
Less intake runner volume is needed
Longer Rod Cons
Closer Piston-to-valve clearances
Makes the engine run a little more cammie at low rpm
Reduces scavenging at low rpm
Old 11-05-2002, 01:08 PM
Slider in Wa.
Post
So are these 6 in rods 400 sbc rods? Will they work with the 350 crank? I`m not getting the picture yet.
Thanks.
Slider in Wa.
Old 11-05-2002, 02:41 PM
Post
nope accually 400 rods are shorter than 350 rods (5.7) 6 inch rods are aftermarket u also have to buy special pistons for the 6 inch rods.
now if your building a 383 u get the crank from the 400 but the rods are crap
