6 Volt or 12 Volt - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2006, 04:32 PM
2000jack's Avatar
1929 Chopped Tudor
Last wiki edit: How to title a hot rod
Last journal entry: 1927 roadster
Wiki Edits: 3
6 Volt or 12 Volt
I bought a used heater blower motor, just the right size for what I need,but I don't know how to tell if it is 6 volt or 12 volt. Then if it turns out to be 6 volt is there any way I can make it work in my 12 volt system? Thanks jack
Old 02-09-2006, 06:03 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Quick and easy way is to set your battery Charger up for 6 Volts, and run it full speed, Note the draw, and speed of the motor, If it seems to slow, and pegs the meter, try it on 12 volts..
There is no data on the motor at all? usually they stamp something into the body of the motor..
If it is 6 volts, you can get a ceramic dropping resistor of proper wattage to run it on 12 volts, at the auto parts store, just tell them what your doing.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 02-09-2006, 08:02 PM
2000jack's Avatar
1929 Chopped Tudor
Wiki Edits: 3
Originally Posted by docvette
Doc here,
Doc
There is no markings and it is painted that brown crinkle paint that you see in the forties early fifties. Anyway thanks for the info, jack
6 volt to 12 volt JimmyL Electrical 4 11-24-2005 12:35 AM
Want 12 volts ,have 2 6 volt batteries. moodier Electrical 12 10-09-2005 06:35 AM
9 volt to a 12 volt dist 65Guera Engine 7 08-25-2004 02:33 PM
6 volt / 12 volt coil question BillyJoe Electrical 3 01-21-2004 04:38 PM
how do i use the 6 volt gauges on a 12 volt system cardsrusa Electrical 6 07-27-2003 02:12 PM
