Thanks! Thanks Top 5 Wiki Tech Article Editors! Thanks!
Updated 11/07/08
#1
Alittle1
169 edits
#2
Crashfarmer
161 edits
#3
Powerrodsmike
125 edits
#4
Techinspector1
112 edits
#5
Oldguy829
85 edits
Read and write hotrodding how-to articles on the Crankshaft Coalition Wiki. See 100+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Electrical
  #1
Old 01-29-2002, 04:08 AM
jbrady jbrady is offline
Post 6 volt to 12 volt headlight coversion
I have a 37 Dodge Coupe that I am converting into a street rod. I want to re-wire it with a 12 volt system, but am not sure what to do about the headlights. What it currently has is a 6 volt bulb inside a glass lense. Any suggestions?
Old 01-29-2002, 07:53 AM
Henry Highrise's Avatar
Henry Highrise Henry Highrise is offline
Moderator
 Henry Highrise's barnstar
Wiki Edits: 4
Post re: 6 volt to 12 volt headlight coversion
You should be able to just change the bulbs from 6 volt to 12 volt bulbs, I did this on an old tractor once. Check at your local parts store and see if you can get some 12 volt bulbs with the same style base on them.
Hotrodding is much more than just owning a hotrod...It is a state of mind!
Old 03-26-2005, 10:27 PM
Jerry Kelley Jerry Kelley is offline
just my opinion
To save later hassels Carefully rip out the old wires and rewire as 12 volt system. Food for thought 42volt systems are coming to the new car industry,it makes sence if you understand the dynamics of electricity.You should be able to find headlite adaptors or complete new buckets you like.This is not such a daunting task, if you don`t know much I`m sure you could find good books onthe subject,the net and this site will be a great help. Just remember everything has to have a "good" ground and solid connections. Go for it. Jerry
Old 03-26-2005, 10:55 PM
36scsc 36scsc is offline
JBrady,
See the following thread for what I did to convert my headlights
Old 03-28-2005, 09:35 AM
JohnTN JohnTN is offline
JBrady,
I converted my 39 Olds from 6v to 12v this past winter. While I think you can just replace the bulb with an equivalent 12v bulb, I converted my headlights to 12v halogen using a conversion kit from RBs for $45.
RBs web site is rbsauto.com. The part number I used was 077-000136. My mechanic did the work and I believe there was a little soldering involved. But it turned out great. Kept everything original except the socket and bulb.
John
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
