Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 6 volt car starting with 12 volt battery
Old 09-02-2012, 07:44 AM
rdupree rdupree is offline
Not sure how you are trying to do this, but DON'T use a 12volt battery to jump start a 6 volt battery. Bad things can happen. You can install the 12v battery as positive ground in place of the 6 volt unit. Leave the lights and radio turned off while you have the 12 v battery installed.
