Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 6 volt car starting with 12 volt battery
Old 09-02-2012, 08:39 AM
timothale timothale is offline
Wiki Edits: 27
6 -12 volts
If you do a conversion to 12 volts you can keep the 6 volt starter. We used to put in 6 volts starters in 12 cars to get them to turn over and start at 40 degrees below. You just don.t crank very long or you can burn it up. And the starter doesn't matter if it is pos or neg ground
