6 volt car starting with 12 volt battery - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-04-2012, 03:43 AM
EOD Guy's Avatar
Just about everything uses 12v nowdays..... most battery supply stores can order you a new 6 volt.
  #17 (permalink)
Old 09-04-2012, 03:16 PM
67Elcamino's Avatar
Damit!!! Instead of spending $90 for a 6 volt battery. Im just going to invest in a Rebel Wire 8+3 kit for $169 and begin the conversion to 12 volt. I dont care much about the lights etc.. Im just interested in getting the car running to test the Engine and transmission.
Soon ill be inquiring as to how to change the coil, points, alternator etc... to 12 volt.
  #18 (permalink)
Old 09-18-2012, 06:28 PM
jseabolt's Avatar
Originally Posted by vicrod View Post
Also, consider the other 6 volt devices in the car like the fuel gauge. 12 volts will fry it. Disconnect it.
Also, disconnect the generator wiring.
The oil pressure and water temp. gauges are mechanical and the ammeter is Ok.
Turn off all other 6 volt equipment.
The wire leading to the coil should have a ballast resister. This will get very hot but helps to limit the current going to the coil. This resister and/or the coil may burn out with 12 volts applied. Possibly replace the coil with a 12 volt but a ballast resister is still required.
Remove the spark plugs and spray some kind of rust penetrating oil stuff into the cylinders. Try to turn over the engine with a wrench before trying to start it in case it is rusted.
Then a pre-lube oil pump should be used to pump oil throughout the engine.
Then spin over the engine with no spark plugs to make sure the engine develops oil pressure.
Fresh gas needs to be flushed through the fuel system. The carb may need to be cleaned.
Check for spark and fuel.
Then put in the spark plugs and_________________________.
vicrod
I'm not a 6 volt advocate but I thought it was to save on copper. If you double the voltage you cut the amps in half so you can get by with thinner wiring.
I'm getting a 6 volt Trabant and I'm considering converting it over to 12 volts just so I can use "off the shelf" components like H4 headlamp bulbs, FM radio, etc..
Otherwise if I need 6 volt bulbs I'm going to have to order them over the internet. Never seen any at AwfulZone or Advance stores. NAPA? There is a light bulb store in Bristol Tennessee that claims to have all your lighting needs and may carry 6 volt automotive bulbs. Hate to drive 30 miles for a lightbulb.
I assumed R2 6 volt headlight bulbs were dimmer than 12 volt H4 headlamps. But several Trabant owners say the lights on a post 1983 12 volt systems don't produce any brighter headlamps and the reason for the chnagover to 12volts was because they added a rear window defogger in 1984.
The seller informed me the battery is weak and may need to be jump started when it arrives. So I went to Tractor Supply and picked up a 6 volt with 625 cold cranking amps. Didn't think I could buy a 6 volt battery at an automotive store.
  #19 (permalink)
Old 09-18-2012, 07:18 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Originally Posted by 67Elcamino View Post
Is there any way of knowing if the battery is any good without acid or water? its completely dry. when looking for a new 6 volt battery can I use any 6 volt battery? like a battery of an RV or motorcycle etc..? Im sorry if these questions seem basic but I dont really know electrical
There were only two really common automotive 6V batteries.
NAPA # 01-9
Attributes
Battery Application : Commercial Service
Battery BCI # : 1
Battery Height : 8 3/4" (222 mm)
Battery Length : 9" (229 mm)
Battery Posts Type : Top Post
Battery Voltage : 6 Volt
Battery Weight : 30.0 lbs (13.6 kgs)
Battery Width : 6 7/8" (175 mm)
Wet or Dry : Wet
and
NAPA # 04-10
Attributes
Battery BCI # : 4
Battery Height : 9 1/2" (241 mm)
Battery Length : 12 1/2" (318 mm)
Battery Weight : 47.0 lbs (21.3 kgs)
Wet or Dry : Wet
Go to any parts store and tell them that you're looking for a 6-volt BCI # (1 or 4 according to those dimensions) and they will sell you what you need.
  #20 (permalink)
Old 09-18-2012, 09:26 PM
vicrod
Many of the bad gauges in the 6 volt cars are due to someone trying to jump start it with a 12 volt battery.
  #21 (permalink)
Old 09-19-2012, 08:07 AM
jseabolt's Avatar
Sort of of on the subject of batteries. This maybe common knowledge but i top mine off with distilled water once a year.
i got 12 years out of a battery until i gave it to my stepson. I thought the battery was bad but turned out the bearings
in the starter was the issue. Dad will replace a battery when the warranty expires. I will push one until it crokes.
I have AAA.
  #22 (permalink)
Old 09-19-2012, 10:15 AM
GMCTRUCKS's Avatar
My brother has a 8 volt battery on his 6 volt VW all he did is turn up the generator it helped a lot for night driving.
Dual Battery 12 volt charging and starting tburris0131 Electrical 14 11-10-2011 09:24 PM
8 volt battery Hershal O. Sims Electrical 8 12-03-2010 05:28 PM
Use of 8 volt battery on 6 volt car! moodier Electrical 8 11-12-2008 12:12 PM
6 volt-12 volt battery question MeEatsPigBrains Electrical 5 11-14-2005 01:49 AM
Converting Headlights from 6 volt to 12 volt seal beams sifua Hotrodding Basics 3 11-13-2003 02:30 PM
