6 volt pos. ground elect.oil psi gage
has anybody ever heard of a 6 volt pos. ground oil psi gage? and if so could you please let me know where i can get one.
don't like the idea of having a oil line in the car with me after putting in new carpeting and stuff. thank you for the help. rick |
Doc here,
Voltage is NOT the issue here..it doesn't care..Polarity is...an oil sender is a passive, resistive device. Is the Gauge you are using Positive or Negative Polarity? Doc
Aftermarket Solutions Electronic & Electrical Innovations |
i haven't bought it yet doc but i think the one i seen at the auto store the other day would be neg ground
i was hoping some one would have a lead as to where i could get one for pos. ground. or be Abel to change one to pos ground thank you for the reply |
i am planing on using it in a 55 thunderbird i don't like the idea of running a oil line in to the car after putting in new carpeting
the guy i bought the car from had a steal line in and i was starting the car and the line broke thank god i did not have new flooring in at the time. if all Else fails i will more than likely run the idiot lights. |
Doc here,
If you use and connect a Negative Ground gauge in that car, It will indicate Backward..(wiring it normally) To DO that, the gauge MUST be isolated off Ground, (no part of the gauge may come in contact with the body) Then, you can use a non conductive fitting at the block for the sender , along with a two wire sender. Fuse at 1 amp. BE ADVISED: if something slips down the road on the gauge mount, you have a DEAD short to ground.. Another option is run instrument regulators, 6 to 6 volt 1 Amp 78XX Type Regulators..Fuse the input at 1 amp, fuse the Output at 1 amp, Fuse the ground at 1 amp...and be advised the REGULATOR (S) must be isolated off the body as well..(It's a positive regulator) Doc
Aftermarket Solutions Electronic & Electrical Innovations Last edited by docvette; 07-23-2007 at 06:00 PM. |
Kaisers were also positive ground and used a pressure sender and wire set-up
thank you all the help i will keep looking for a gage but if i can not find one i will use the lights or run a copper line as much as i don't want to but to not know if there is a problem with the oil psi is worse than getting oil on the carpeting.
again thank you all and if you come up with something please let me know rick |
Doc here, If it ends up you need to go to SS or Copper line.. A good fail safe that has worked for me, is get some rubber hose that will fit over the Copper nut/Compression nuts and the line..and run that all along the line out to the engine bay... Use a hose clamp on the gauge compression nut and hose, (right up to the gauge as close as you can get it.) and leave the sender side open to the air, Do not clamp.. Set the line at a slight grade all the way (so any leaky oil will follow gravity inside the hose, down the hose and out of the car) and that should protect the interior. IF it leaks, it will flow out into the engine bay and on to the ground. Doc
thanks doc that sounds good to me
rick |
| 6 volt pos. to neg. ground | rick laplante | Electrical | 9 | 10-16-2006 01:50 PM |
| '55 T-Bird 12 volt conversion | Sidn | Electrical | 4 | 08-29-2006 09:03 AM |
| How Does This Stuff Work? | docvette | Electrical | 3 | 06-18-2006 03:00 AM |
| what stereo wires under carpet? | bullheimer | Electrical | 19 | 05-06-2005 06:37 PM |
| 39 Ford - Neg or Pos ground? | Tiger | Electrical | 16 | 11-14-2002 03:56 AM |
